Old 09-26-2013, 10:21 PM
hiwayman hiwayman is offline
Default Refilling bowls via vent tube
hi carb gurus i can fill the secondary through the vent tube but the primary fuels leaks outs before the blades is thie posible?
Old 09-27-2013, 01:07 AM
Vince@Meanstreets's Avatar
. That just means the primary is full or power valve is ruptured. If this is at initial fill then pull your float site plug or watch for the float if you have the site glass.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 09-27-2013, 01:10 AM
Tell us more of your scenario.
Dealer for
NEVER FORGET -11
Old 10-01-2013, 06:37 PM
hey vince i will try filling them abit slower,i have just converted a 1050 braswell 3circuit to a 2circuit using QFT metering blocks relocating the idle fuel jet and a massive diffrence in idle quality from super rich to tunable lean i have the innovate LM-2 also idle is 14.0.1. i have come down from a 36IFJ to a 24 with a 71air bleed real happy with the results so far.
