Old 02-01-2014, 03:31 PM
glr0212 glr0212 is offline
alignment
Camber -0.48
Caster +3.77
Toe in 0.03"
Old 02-01-2014, 03:36 PM
Originally Posted by bret View Post
Your tire hits the outer fender because the 265/45-18, at 27.4" tall, is about 1.8" taller than the 25.6" tall 275/35-18 tire that we (and most others) use. It hits the subframe at full lock because you've selected the wrong wheel back spacing by 1/2". Our printed recommendation for back spacing is 5.75".
If you install the correct parts on the car it will fit just fine.
The tire is a 25.3" tall
265/35ZR-18 BFGoodrich g-Force T/A KDW 2
thanks for your help.
Old 02-01-2014, 03:41 PM
Originally Posted by Josh@Ridetech View Post
Hey GLR0212,
I'll be happy to help you figure this out, I just want to check into a couple of things to see what we're working with. I saw up above where you said you used our alignment specs but can you tell me exactly what you have your camber set at? We ran a 275 on the 69 GG/RS Camaro that we just finished. We just need to see where your problem is coming from.
I posted the alignment specs above. What is the ride height on the GG camaro? Measured at what point?
Old 02-01-2014, 04:10 PM
Rod P's Avatar
Rod P Rod P is offline
Originally Posted by glr0212 View Post
  • ½” Drop body bushings
  • 18x9.5” front wheel w/ 6.25” backspace
get rid of the half height body bushings, that tucks the frame higher into the body
and that wheel backspacing (6.25” backspace) is more for a scott mock style frame that has the corvette arms
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 02-01-2014, 04:37 PM
i think we are missing something in communication here.
I clearly do not have room to move the wheels and tires OUT 1/2". The fender is already sitting on the wheel practically. I'll get another picture later to demonstrate this for you.
Also not sure how body height bushings are going to create more side to side clearance in the fender wells.
Old 02-01-2014, 05:17 PM
dhutton dhutton is offline
but thanks for your help.
Your first post says it is a 265/45 tire....
Won't half height bushings tuck the tire further into the fender and aggravate the problem?
What about adding a litte more camber?
Don
Old 02-01-2014, 08:01 PM
Vince@Meanstreets's Avatar
Yep, 5.750 would put you into the fender.
I'd go -1.8 on the camber and see what you have to do to keep your turn radius. Looks like its in the sway bar hardware already.
I don't see a problem with the half heights in there. It's the same as lowering the car as far as clearence.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 02-02-2014, 07:57 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
You're right, there's only so much room to fill. To get it off the fender, you need more backspacing, but that makes your frame clearance worse.
Looks like the wheel is already in negative camber. More would help, but you can't go to far.
The only way you're going to make this set up work is to raise the car a little, and notch the frame where the tire hits.
Old 02-02-2014, 09:05 AM
jlwdvm jlwdvm is offline
So are we saying that this set up (if used per Ride Tech's specs) works on some 69's but not others? Is there something "non-stock" about the G/RS set up? I'm looking for answers before I buy wheels and I have the same set up as what is being discussed here...except I have solid Alston stock height body bushings.
Old 02-02-2014, 10:44 AM
bret's Avatar
bret bret is offline
Supporting Vendor
Could you post pic of the tire size? I'm not finding a 265mm tire in a kdw.
The standard height subframe bushing will serve to raise the body/fenders by about 1/2". You can simulate by adjusting the coilovers up to test fitment.
Also, additional camber will help fender clearance, help turn in for autocross ing, and will not significantly harm tire life
I routinely run cars with 1-1.3 degrees of camber on trips across the US. Theoretically that much camber will decrease tire life but we abuse our tires in so many other ways it doesn't matter.
Bret Voelkel
President
RideTech
Air Ride Technologies, Inc.
