Old 09-18-2014, 01:34 AM
358Mustang 358Mustang is offline
SO now I am working on just making my own spindles. This seems like the best route for me, since I can dial in exactly what I want. I found some photos of some of the Trans am spindles, I plan on using a similar design. Mono ball upper/lower joints. Ive got speedway engineering 5x5 grand national hubs and coleman sells a weld on spindle pin that I am going to start building off..
Here is the spindle I was going to steal some ideas from and build it similar to this guy.
Id like to end up in the 6 degree KPI range and zero (or less than an inch) of scrub with an 18x11.
Old 10-12-2014, 08:39 PM
Made a little progress. Made a motor plate and got that tacked in. I needed to set the motor where I wanted it, next I plan on building the "sub frame" for the lower control arms. I think I am getting things figured out. I know I am 7" back from where my old motor was. And I had my old motor 2-3 inches back. So I'll call it 10" set back. Unsure on the height but the engine is very low in the chassis. I think I should be ok with pan clearance, but I have already explored some options of making a pan about 1-1.5" shorter if I need.
I'll have front and rear plates, as well as a tranny mount..
Old 10-12-2014, 08:44 PM
dstryr dstryr is offline
You made the engine plate? LOL
Dennis
www.creationsultd.com
1969 Chevelle Build - Meanstreets Performance Style
https://lateral-g.net/forums/showthread.php4?t=39456
Old 10-12-2014, 08:48 PM
If you closely interpret my posts. I said... "made a motor plate" .That could mean I made it, some kid in china made it, or in this case you cut it for me. And did the high quality programming
Old 10-12-2014, 11:26 PM
DBasher's Avatar
DBasher DBasher is offline
Are the front rails in the factory location, width wise?
Motor plate looks good, interested in seeing this come together.
Dan
Old 10-12-2014, 11:29 PM
I don't care who made it - it looks good!
Why not have your "machinist" (LOL) make you some uprights out of billet material?
Old 10-13-2014, 12:21 PM
Vince@Meanstreets's Avatar
That would be a chunk and a half.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 10-13-2014, 08:28 PM
Track Junky's Avatar
I agree with Greg. Looks great. Hope this project doesn't take you to long......looking forward to seeing you at the track next season.
Gaetano Cosentino
Old 10-13-2014, 08:44 PM
Brian
We should go halves on a flatbed trailer for when both our cars are done
*Cough* Vince *Cough*
Dennis
Old 10-13-2014, 08:45 PM
Motor plate made by same clown that made your sway bar clamps........................
Dennis
