Old 09-13-2018, 07:38 AM
kwhizz's Avatar
kwhizz kwhizz is offline
Another update...…… We were planning on taking the Nomad on the Good-Guys Road Tour next week.... I had a intermittent problem that kept cropping up...… I would get in the car and turn the key and click, click, click...… Battery was fully charged..... Humm !!!……. Went thru the Battery cables, cleaned tightened and thought the problem was solved.... Till it did it again...….. replaced the starter...…..problem solved.... Not !!!...…… Replaced battery cables...….. Same thing...… The only thing left that makes any sense is the Ignition switch...…. No time to get a "Real" GM switch and replace it......So... The Nomad is staying home and the Chevelle is going instead...…. Darn.... This car stuff is hard !!!!!
Ken
Old 09-13-2018, 08:09 AM
NAPA 68 NAPA 68 is offline
Ken
Did you put a new harness in the car? I had a problem some time ago with the original harness bulkhead with corrosion. It provided a periodic voltage drop in the trigger wire for the solenoid.................click click!
It would absolutely suck if you could not take the Nomad. You certainly have paid you dues with that build!
Old 09-13-2018, 08:31 AM
Wait Ken --- Remember when I drove (rode in - Rudy drove the entire trip) - the Chevelle and it was doing that --- and it was like the neutral safety switch connection or something.....
Come on buddy - don't give up on her!
Old 09-13-2018, 09:36 AM
kwhizz's Avatar
Yes.........All new wiring in the car.....American Autowire kit.......
Old 09-13-2018, 09:50 AM
kwhizz's Avatar
Greg...... Different situation...... Ended up being a loose alternator connection to the Battery.......Voltmeter showed voltage but the amperage wasn't getting thru to the Battery......and the Battery was getting minimal charging..... Found the problem after we got the car home last year..... The 10 ga wire I had going to the battery (way too small I have since learned) covered in the plastic casing....... Couldn't see the wire because it was inside the casing, but I smelled a weird smell in the engine compartment and was looking around and I noticed the casing was melting at the alternator....From the loose connection resistance heated the wire and pretty much melted the insulation...... It also took out the alternator.....I did some research and found out that with the Electric fans at least a 6 GA wire was required.... New alternator and 6 GA wire and now I can have everything running and the Voltmeter stays at 14 Volts...... Another education to the guy who thinks he knows everything.....LOL......
I are Smart !!
LOL
Ken
Old 09-13-2018, 04:50 PM
kwhizz's Avatar
Here was the problem in the Chevelle !!….
Old 09-13-2018, 10:36 PM
Just so you know -- we could all be touring in brand new 488's or Bentleys for what we have in all this crap.... God only knows why we do this. But damn I love it anyway! LOL
Just thinking about the clicking ----
Check grounds from motor to chassis etc
Check voltage at starter motor for voltage drop
Check voltage at ignition vs battery
Bypass ignition and hot wire -- to see if she starts
Neutral safety switch contact (assuming there is still one in the car)
The Following User Says Thank You to GregWeld For This Useful Post:
glassman (09-14-2018)
  #208
Old 09-14-2018, 06:42 AM
kwhizz's Avatar
In reference to the Chevelle...…….There was a loose terminal on the Neutral safety switch...…… since corrections the car is back to it's old reliable self...… (probably shouldn't have said that) LOL...….
Ken
Old 09-14-2018, 06:51 AM
kwhizz's Avatar
Yep !!!...……. Donnie at Frame-up checked everything as above and we thought everything was O.K...…… Till it happened again..... That's why we suspect the Ignition switch....
Ordered a GM switch and it will be replaced when we get back from the tour.... Hopefully it will make it on next years tour
Old 09-14-2018, 08:32 AM
dontlifttoshift's Avatar
dontlifttoshift dontlifttoshift is online now
We checked all the basics, found a questionable connection at the negative on the battery and the car started 50 times after that over the course of two days without hesitation...........Ken called two days later and said it clicked again.
Donny
