Old 01-17-2016, 12:28 AM
burntnova burntnova is offline
Default Question for any Engine Buider
This un related to my nova build but I race Dirt track midgets that I run a 2.4L ecotec motor in and I'm building a new motor for the upcoming season and I have a few questions.
Does it make a difference if I get the rotating assembly balanced?
What benefit do I get by using a stronger valve spring on a stock long block and head?
If anyone has knowledge to school me on this I'd appreciate the help.
Old 01-17-2016, 06:11 AM
Travis Travis is offline
Default The only way to go
Balancing your bottom end is probably the most important thing to do! The only down side to doing this is the price, you will only ever benefit from it. Your engine will perform smoother throughout the rev range, it will rev easier & quicker, you could hold it on the rev limiter all day long without a problem. Most of all the life expectancy of the engine will be dramatically longer.
As for your valve spring, a stronger spring than stock is beneficial especially when your in the higher rev range. If your using any sort of performance camshaft then stronger springs are a must.
Once you've balanced your bottom end, then it's time to get your engine breathing, in & out, get your head flow tested & then your camshaft which tells it when to breath and for how long & those are the ingredients to any bullet proof engine!!
