Old 02-09-2016, 07:28 PM
aany001's Avatar
aany001 aany001 is offline
Default LS conversion throttle cable
Hey guys need a little info on a throttle cable. I have an LS drive by cable in my 69 camaro and a 6 cyl throttle pedal. Is there an OEM throttle cable that I can use? I am aware of the Lokar setups but want an OEM looking cable. I'm sure this has been done before. I've researched it and have found a few different cables that work. I've picked up 2 at the scrap yard as testers but no luck yet. Getting real close for my first road test and wanna wrap this issue up.
Steve
Old 02-09-2016, 11:10 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
i am using the lokar cable with the black sleeve and a modified factory bracket. I wanted a stock look and thats the best I could come up with.
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 02-10-2016, 05:06 AM
aany001's Avatar
I wanna try and buy here in Canada cause our dollar is weak right now so that $60 cable turns out to be 110.
