Old 03-19-2016, 03:51 PM
PBritain's Avatar
PBritain PBritain is offline
Default New Guy With A Cordoba
That's right, a Cordoba!
Hey everyone, new to Lateral G but not new to car building and racing. Looks like a cool place to draw a lot of inspiration and learn a bit about what other people are doing with their builds.
I've had my car about two years now, and the goal has been to create a car that looks and performs like the NASCAR type cars that went to Le Mans in the mid 70's, but on a very very tight budget. So keep that in mind (plus it is very much a work in progress) when you see some pictures of my car!
The entire drive train has been gone through already with a rebuild 360, 46RH overdrive trans, 8 3/4 rear end with posi and 4.56 gears. The interior is gutted with sheet metal door panels and two bucket seats. Next up is the front suspension that is going to get larger sway bar, larger torsion bars, new shocks, tubular upper control arms, and polyurethane k member bushings. The goal here is to build it the best I can without reinventing the wheel or buying a crazy expensive kit. Just going for bolt on performance here.
Anyways, I'll get a build thread going at some point, but for now it's nice to be here.
How it looks now.
Engine shot with air intakes removed to see more. (Inner wheel wells had just come out, so forgive the horrible firewall)
Interior pic (The dash has since been painted black, and this is pre-ratchet shifter)
1975 Chrysler Cordoba
"Chargoba"
Old 03-19-2016, 07:36 PM
Che70velle's Avatar
Welcome to LatG! Love the car! Is this a driver, or a track car?
Thanks Dad!!
Old 03-21-2016, 04:17 PM
PBritain's Avatar
Thanks!
It is a driver, but not my daily. The plan is for it to remain very streetable, but also right at home at the track.
"Chargoba"
Old 03-22-2016, 05:38 AM
im4u2nvss im4u2nvss is offline
Way to go trying something different. Brought back memories of my 1st car(1980 Cordoba). I assume parts and support will be hard to find. Good luck!
Old 03-22-2016, 06:30 AM
SSLance's Avatar
SSLance SSLance is offline
Welcome to Lat-G. Looks like you've got a good start on your car already, any idea what it weighs as it sits now?
I have a soft spot for those that do things the hard way and on a budget, keep up the good work.
Lance
Old 03-22-2016, 06:50 AM
Rod P's Avatar
Rod P Rod P is offline
awesomeness!!!! welcome
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 03-22-2016, 04:06 PM
Radlark's Avatar
Radlark Radlark is offline
Welcome to Lat-G I saw this a couple of Sundays ago at the Pomona Fairgrounds, man that thing sounds mean!!!!
Old 03-22-2016, 04:34 PM
PBritain's Avatar
That's awesome, and thanks for the compliment!
Last time I weighed it was before I removed the heater core, the inner fender wells and some little miscellaneous stuff. Believe it or not, it weighed in at 3878 as measured on Quantum corner scales. I figure we are just under 3800 now. The goal is to get down to 3500. Making aluminum bumper supports should get me most of the way there, lexan rear window will be next, and then rewiring the thing should save a lot too.
"Chargoba"
Old 03-22-2016, 05:56 PM
jarhead's Avatar
jarhead jarhead is offline
cool!
joe
Semper Fi
My 68 Torino
Old 03-22-2016, 07:41 PM
Welcome to the site! I like the theme you're going for. Be sure to start a build thread on the car too.
