Old 03-04-2020, 07:55 AM
Gscherer78ta's Avatar
Gscherer78ta Gscherer78ta is offline
Awesome content and put together very well! Very enjoyable!
Greg
'78 Trans Am - Y88-R LS3/T56,
Holley EFI, UMI Performance
The Following User Says Thank You to Gscherer78ta For This Useful Post:
1970RT (03-11-2020)
  #122
Old 04-06-2020, 09:43 AM
1970RT's Avatar
1970RT 1970RT is offline
Thanks, Greg. It actually helps a lot with my build process to take a minute and edit a video - if I can't explain it, how do I know it's my best work?
Meanwhile, I'm building the next one about frame construction. Here's a load of photos related to engine mounts and the first interframe crossmember.
David
The Following 2 Users Say Thank You to 1970RT For This Useful Post:
Goosesdad (04-07-2020), Roscoe03 (04-06-2020)
  #123
Old 04-06-2020, 04:27 PM
ScotI ScotI is offline
Are you having your brackets cut by a local shop? I'm waiting for some brackets to be cut for upper C/O mounts. It would be nice to have options for someone around DFW that can cut/do small jobs.
Old 04-07-2020, 08:24 AM
1970RT's Avatar
I am.
I use Western Sheetmetal for quick laser work, but they're pricey. Davis has better prices, but takes forever. Also, a buddy of mine has a plasma table, and let's me use it. It just depends on the size, detail, and when I need it.
David
The Following User Says Thank You to 1970RT For This Useful Post:
ScotI (04-07-2020)
  #125
Old 04-07-2020, 09:17 AM
Originally Posted by 1970RT View Post
I am.
David
Thanks for the info.
The Following User Says Thank You to ScotI For This Useful Post:
1970RT (05-27-2020)
  #126
Old 05-27-2020, 11:43 AM
1970RT's Avatar
Frame build, part one, is now live. There's some good detail on how we built out the rails, because nothing "clicks together." Part two is around the corner, and deals with the Chassisworks front suspension crossmember.
David
Old 05-29-2020, 09:55 AM
1970RT's Avatar
Part deux.
David
Old 05-29-2020, 12:17 PM
python python is offline
awesome chassis.
The Following User Says Thank You to python For This Useful Post:
1970RT (05-30-2020)
  #129
Old 05-29-2020, 12:19 PM
Not sure if it's me only, but I don't see anything in the last 2 posts (126, 127) except for the text (no images/attachments).
I can see the images from post 122 & before.
Old 05-29-2020, 06:19 PM
syborg tt's Avatar
They are video links.
marty-mj
