Old 12-03-2020, 07:35 PM
Stielow's Avatar
Stielow Stielow is offline
Congrats! Early Christmas gift to yourself or do you think it'll be 2021 before it's done?
Hope to have it on the ground around Christmas
Stielow Engineering
The Following 4 Users Say Thank You to Stielow For This Useful Post:
dhutton (12-03-2020), fleetus macmullitz (12-04-2020), kwhizz (12-04-2020), will69camaro (12-03-2020)
  #582
Old 12-03-2020, 09:32 PM
F'in mine's Avatar
F'in mine F'in mine is offline
Mark, in case I missed it could you elaborate on your driveshaft setup you're using?
4" aluminum, carbon, steel, 1350's? Tks.
1969 Camaro SSRS
Simon
Old 12-04-2020, 11:20 AM
Stielow's Avatar
3.5 QA1 Carbon. 1350 U joint
Stielow Engineering
The Following 6 Users Say Thank You to Stielow For This Useful Post:
130fe (12-06-2020), F'in mine (12-04-2020), jmac (12-04-2020), kwhizz (12-04-2020), will69camaro (12-04-2020), WILWAXU (12-06-2020)
  #584
Old 12-04-2020, 07:05 PM
Stielow's Avatar
Going back together
Stielow Engineering
The Following User Says Thank You to Stielow For This Useful Post:
  #585
Old 12-04-2020, 07:07 PM
Stielow's Avatar
Stielow Engineering
fleetus macmullitz (12-05-2020)
  #586
Old 12-04-2020, 07:57 PM
jmac jmac is offline
Car looks amazing Mark. You must be dying to get it buttoned up and shake it down. I'd love to hear the exhaust with the new mufflers you're trying out.
2 questions for you. Can you explain the vent plumbing you have going on your tank? I know some guys have had some trouble with venting their tank and spilling fuel.
The other is how you went about securing your lines under the car. I'm ASSuming the brake line, you drilled and tapped the DSE subframe connector? But what have you done in the thinner floor pan material?
As always, thank you for taking the time to share and answer our questions!
My 1967 Camaro
Old 12-05-2020, 06:42 AM
Stielow's Avatar
A fuel tank needs room to vent. The lines attempt to connect the vent to the highest point in the tank. One up on the filler neck and the other on the top corner. They Tee together then go up to the TooMuch vent in the trunk. Hope it works. If not I’ll add a expansion tank. The issue in the summer we pump 70 degree fuel into a car when it is 90 degrees out side. The fuel expands and fills the TooMuch vent. OE ad a dome or expansion area for this. In hot rods we want all the fuel volume we can get.
We route the brake lines the best we can on the subframe. Going rear we end up riding them down to the bottom of the car on the sheet metal. Because of the ABS it is 2 rear brake lines.
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
fleetus macmullitz (12-05-2020), WILWAXU (12-06-2020)
  #588
Old 12-05-2020, 11:30 PM
Beechy's Avatar
Beechy Beechy is offline
A fuel tank needs room to vent. If not I’ll add an expansion tank. The issue in the summer we pump 70 degree fuel into a car when it is 90 degrees out side. The fuel expands and fills the TooMuch vent. OE ad a dome or expansion area for this. In hot rods we want all the fuel volume we can get.
OEMs have a"dead man" in a fuel tank......basically an inverted pie tin with a pinhole in the top surface.
When you thought you'd filled the tank, air is still trapped in the pie dish void and the fuel nozzle cuts out. The pinhole allows controlled venting to occur, so that when the fuel increases in temperature and volume (now that it's out of the ground), it swells into that void and doesn't puke out the vent lines.
THATS WHY YOU DON'T TOP OFF AFTER THE FIRST CLICK.
TOOmuch vent chamber gives the liquid/air time to settle out and is a great feature........but can't cope with massive west-coast changes in temp out of the ground vs. cooking in 95* ambient.
Aftermarket tanks don't have this feature.
Competing claims to the largest volume compared to the competition?
Carl?
Jim Grant
Melbourne, Australia
(Dual citizen)
The Following User Says Thank You to Beechy For This Useful Post:
Fluid Power (12-30-2020)
  #589
Old 12-06-2020, 12:16 AM
marine15Z28 marine15Z28 is offline
Where did you get those rotors Jhook slotted?
Old 12-06-2020, 06:11 AM
Stielow's Avatar
Arron Oberle did them for me. He also made the emblem, dash bezel and shifter ring. Great guy and great parts. Working with him was some of the funnest part of this build.
Stielow Engineering
