Old 11-03-2021, 09:45 AM
68454RS's Avatar
68454RS 68454RS is offline
Originally Posted by 69C40Hx View Post
Can confirm the Magnum-F is a direct swap in a 69 Camaro with regard to the physical size/location of the transmission when compared to a T56 out of a 98-02 F-Body.
This should be the only Tremec Magnum transmission (Magnum-F) anybody with a first generation Camaro should be considering when swapping to a T56 nowadays.
When purchasing a new unit from Bowler or Jody's , why the Magnum-F over just the Magnum?
Old 11-05-2021, 08:32 AM
samckitt's Avatar
samckitt samckitt is offline
Does the Magnum F use a different speed sensor than the regular Magnum? The regular Magnum uses a Ford sensor, wondering if the "F" uses a GM one that matches the pulse output count as a regular GM T56.
EDIT: That would require a different target wheel on the output shaft too wouldn't it?
Scot
86 Monte SS
LS2/T56 Magnum
Old 11-10-2021, 09:36 AM
gnx7's Avatar
gnx7 gnx7 is offline
The Magnum F style is supposed to be a duplicate offering for the '99-02 style T56. The main difference is the 31 spline yoke needed. I like this transmission better as the 4 bolt shifter offerings are much better than the standard Magnum T56 6 bolt style shifter. The F style comes with a pretty nice billet shifter... but most opt to install an MGW shifter etc instead.
Old 11-10-2021, 06:26 PM
68454RS's Avatar
My trans guy is selling me on a Red Roberts shifter
https://redrobertsinc.com/
