Old 08-16-2022, 09:29 PM
Mad_Monte_Carlo's Avatar
Mad_Monte_Carlo Mad_Monte_Carlo is offline
If the president of Ridetech is telling me the adjustments don't really work due to the high spring rate, it would lead me to believe it would be time to try a lighter spring rate.
Old 08-17-2022, 11:34 AM
dhutton dhutton is offline
Bit of a misunderstanding. There is no compression damping adjustment because they are monotube shocks and high spring rates aren’t affected by adjustable compression damping is what I was told.
Don
Old 08-17-2022, 11:36 AM
Originally Posted by randy View Post
I didn’t realize the ride quality difference in my ridetech coilovers till I switched my rears to jri and had Jj valve them at ultimate performance. I wish I would have went with the jri from the beginning
This is interesting. My Art Morrison subframe and IRS also had JRI coilovers.
Don
Old 08-18-2022, 10:11 PM
randy randy is offline
Originally Posted by NOVA View Post
This is Interesting ..... glad it made a noticeable difference in your case, how did it change, do you feel it took the harshness out of the ride or ?
Yes. When hitting a bump it was just smoother instead of instant Jolt. I also felt my rear suspension gripped better on the autocross track as well coming around a turn. Now understand my car is very low and for a simple coilover change I felt a huge difference. I prob have 5-8k miles on my new setup.
The Following User Says Thank You to randy For This Useful Post:
NOVA (09-17-2022)
  #35
Old 03-21-2023, 11:56 PM
NOVA NOVA is offline
Question
it is encouraging to know the JRI change and/or the re valving made a large difference for the rear, encouraging to hear smoother.
Question, did you do anything with the fronts as far as changing or re valving or are they still the original Ridetech that came with the coilover kit ?
Forgelines - Ridetech - DSE Tubs - ZZ4/700R
