Closed Thread
Old 05-29-2021, 08:31 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Default 1967 Pro Touring Camaro
Item Location (City/State): Las Vegas, NV
Price: https://bringatrailer.com/listing/19...et-camaro-123/
Description: 1967 Pro Touring Camaro
Wheels/Tires
Wheels: Forgeline VR3P 19” with custom offset specific to the car.
Tires: Michelin Pilot Sport S4s
Front: 275/30x19
Rear: 305/30x19 (capable of fitting up to a 325 rear)
Wilwood AERO6 for Corvette C6/Z06 with Nickel finish
Front: Six (6) pistons with a 14.25” drilled and slotted Rotor
Rear: Four (4) pistons with a 14” drilled and slotted Rotor w/internal parking brake
Hydratechs Hydraboost booster with Wilwood Master Cylinder
StopTech electric parking brake
Frame/Chassis
Art Morrison Enterprises 67-69 Sport GT chassis
Front: AME Sport GT bolt in chassis with Corvette C6 suspension,
DSE power steering rack 20:1 ratio, T56 transmission cross member, weld in frame connectors tie front and rear together.
Rear: AME 67-69 triangulated four bar weld in rear chassis complete.
Ford 9” rear end, strange center section, Strange 31 spline axles and 3.70 gears
*Note: Frame and components powder coated black.
Body
All original, rust free GM steel 1967 Camaro RS (*with the exception of the roof). Body taken down to bare metal and professionally finished to show quality.
DSE Deep tubs
DSE Roll bar
Smoothed Firewall
Smoothed door/trunk locks (*removed)(Now electric)
Original GM window molding and trim restored to show finish
Rear bumper smoothed and refinished with show quality chrome
Pilkington Auto Glass w/OE fit and green tint
DSE Fender brace kit
DSE Billet Hood Latch & Spring Collar
DSE Stainless steel hood latch trim ring
Ridetech Stainless steel fuel cap and filler
Ring Brothers billet Hood Adjusters
Ring Brothers billet Door Sill Plates
Ring Brothers billet Door Strikers
Carbon Fiber front spoiler
RS grill, trim, headlight doors and covers
Backup and Marker lights with LEDs
Marquez Design Billet taillights with Digi-Tails LED panels
ARP 12 point stainless bolts and custom washers used in most areas
Bottom of car and wheel wells coated with UPOL Raptor Liner
All doors, roof, firewall and rear quarters lined with Dynamat and Dynaliner
Electrical/Electronics
DSE Selecta-speed wiper kit
American Autowire wiring kit
MODO Innovations keyless entry kit
MODO Innovation keyless trunk release
Dakota Digital keyless remote door locks
Dakota Digital HDX gauges with dimmer
67 Camaro RS electric headlight kit
Vintage Air Air-conditioning
Howell EFI engine harness with GM 02 & knock sensors.
GM Corvette gas pedal
GM E38 ECM with LS7 tune calibrated to engine parameters.
All bulbs are LED.
Nu-Relic Power Windows (Front only)
Interior
Recaro Specialist “S” with black leather
Crow Enterprises Four (4) point race harness
The Shop LLC, Kick panels and package tray cover in black leather
TMI black headliner, sail panels and visors with Impala print
MODO Innovations pedal covers
Ring Brothers adjustable shifter
GM Tilt steering column with Stainless hardware
NRG short steering hub adaptor and quick release
MOMO Steering wheel
LED dome and floor lighting
Custom Leather Door Panels designed to look stock
Focal/JL Audio sound system
ACC Essex cut carpet and matts
Engine/Transmission/Fuel
LS7, 7.0 liter, 427 c.i. (548 rwhp and 493 Tq.)
BTR stage III cam
Stage II ported heads
LSx dual spring kit w titanium retainers, steel seats, seals/locks
Titanium sleeved exhaust valves
Comp Cams trunnion kit
Titanium Lash Caps
LS7 Fly wheel
ACT Clutch
Tremec T-56 Magnum-F six speed (2.66) Transmission.
3” aluminum drive shaft
Peterson Fluid Systems ATS 2 gallon Dry Sump oil tank and breather
C&R Radiator 2pass/LS with transmission oil cooler
SPAL dual 11” fans
Holley Mid mount serpentine accessory drive.
Holley valve covers and fuel billet fuel rails
Custom 3” cold air intake tube with close out panels
Ricks Hot Rods stainless fuel tank VaporWorx kit with LS3 fuel pump.
II Much Engineering Fuel venting system
[IMG]https://bringatrailer.com/listing/19...et-camaro-123/[/IMG]
It was funky music or the wind in the microphone... or you can mute it.
Thanks for Bidding!
Curtis
Old 05-30-2021, 08:00 AM
Sheck44's Avatar
Sheck44 Sheck44 is offline
Curtis ... WOW ... just gave you some props ...
Cheers
Steve
'Build it RIGHT the 2nd time'
69' SS X11 PRO-TOURING - SOLD
73' FJ40 LS - SOLD
1966 FJ40 R2.8 -SOLD
911 Hotrod - SOLD
2002 Gated 360
Next up - "Killer Piggy"
The Following User Says Thank You to Sheck44 For This Useful Post:
Spiffav8 (05-30-2021)
Closed Thread
