Old 03-28-2007, 03:57 PM
Majik16106 Majik16106 is offline
Default simple 91oct 355 builds?
Does anyone have or can link me to anyone who has done any decent 400+ hp pump gas 355 builds?
1964 Triumph Tr4a Restored Road Racer
2004 Nissan 350z Daily Fun
Project Ronin - Will be working on it til i die
Old 03-28-2007, 04:02 PM
Sales@Dutchboys's Avatar
Im building one right now....well mines going to be about 110What would you like to know? maybe I can help
dutchboyshotrods.com
269-823-2967
Old 04-11-2007, 01:06 AM
jamesg602 jamesg602 is offline
Talking
If your looking for a combo here is one, sorry i don't know any builders
http://www.ryanscarpage.50megs.com/combos10.html
Old 04-11-2007, 04:22 PM
cutlasskid cutlasskid is offline
http://airflowresearch.com/
Old 04-14-2007, 08:52 PM
markss28 markss28 is offline
looking on the link it shows that a 383 wiht 9.4:1 comp made over 500hp. Sounds very high for the kind of motor.
Never Stay Stock
Old 04-23-2007, 11:25 AM
Scotch Scotch is offline
Here's both 355 and 383 builds for 87-octane. Easy to duplicate- minimal fabrication required. Builds are identical except for stroke and piston (obviously).
http://www.compcams.com/Community/Ar...?ID=1945664039
Good quality parts and a well-researched combination makes for great power.
Honestly, there's not much vacuum at idle though. If that's not a big deal, this setup works great!
~SP~
Old 04-23-2007, 03:34 PM
chicane's Avatar
chicane chicane is offline
I did one back in '98 with a Goodwrench 350. Paying close attention to the quench, via FelPro's 1010 rubber coated gasket, a set of 195cc TFS aluminum with cnc'd chambers, a Comp Cams XE series camshaft topped off with a Performer RPM Airgap and a Holley HP series 750... it netted 438hp on 87.
Then... CHP did a very similar build in Feburary 2001. 411hp on 87... with ease. With pretty much the same parts. Hummmmm Now if I could find a link to the actual article....
This is part of the series that stemmed from the Feb 2001 build. It was a cheaper build with different parts yet still netted 390/425. Change a part or three... and you could have 425+ hp and still keep it on the cheap.
Old 05-13-2007, 12:39 PM
Blown353 Blown353 is offline
Here's what I built back in 2001. It made 455hp @ 6100 and 435 ft-lbs at 4800.
350 4-bolt main block, bored .020 over
JE Pistons, Teflon coated skirts and Ceramic coated domes, 9.25:1 compression
Cola 4340 crank
Manley 6" H-Beam rods
Comp XR294HR hydraulic roller cam
Comp hydraulic roller lifters
Dart Pro-1 heads, 72cc chambers, 200cc runners, out of the box
Fel Pro 1010 headgaskets (.040" compressed)
Comp Pro-Magnum rockers, 1.6 on intake, 1.5 on exhaust
Dart Stud Girdles
Dart single plane intake manifold, same thing as a super victor (later changed to a Dart dual plane)
Demon 750 carb (started with vacuum secondaries, changed to a double pumper)
M55A oil pump
The engine had a really nasty sounding idle and ran great... from 3000rpm on up. I drove it daily. It was a total dog below 3K rpm and was no fun in my 3620# car until I put a higher stall converter in it which really hurt the street manners. Let's put it this way-- the bottom end was so soft in the original configuration I could NOT powerbrake the car with a 2000 stall GM converter, a 700R4, and 3.42 gears. It simply would not spin! I later changed to an RPM Air-Gap dual plane and it signifacantly helped the bottom end.
In all honesty, being my first "from scratch" build I did the classic bonehead move of over-camming, over-intakeing, and under-compressing. If I built it again I would use a dual plane intake from the start and go with 10.5:1 compression or so which would still be fine on pump gas. I would also like to have tried a Comp XR284HR or equivalent back to back as I think the smaller cam would have suited the 353 cubes better; if the engine was a 383 or 406 the 294 would have been a better match.
It also ran just fine on 87 because of the cam/compression combo. It all worked out in the end though, as the shortblock/heads/compression ratio were just about ideal for boost.
1969 Chevelle
