Old 01-15-2018, 04:36 PM
76TA 76TA is offline
1/15: Update
Took a few photos of the undercarriage after media blast round 2. I still have to tighten up a few areas with some extra welding prior to laying more seam-sealer / dropping it off for paint. Here are a few photos of that.
I also did a rough price out of how much it would cost to lay Lizard Skin Thermal and Sound in the interior. That stuff isn't cheap. Supplies alone with 4 gallons of each runs roughly $450. Seems pretty steep. I might hold off on the Lizard Skin until the spring.
Old 01-16-2018, 09:16 PM
syborg tt's Avatar
Great project looking forward to seeing more pictures
marty-mj
Old 01-17-2018, 11:14 AM
How do you like that Holley tunnel piece? Thinking that might be easier and cleaner than me making my own.
Old 01-17-2018, 08:26 PM
It’s great. I really wanted to keep the factory console as I want to keep the interior as stock looking as possible. That was what pushed me over the edge really. Installation was roughly 3 hours minus the time mocking up the t56.
It’s a great product overall. If I could do it all over again I’d definitely take the same route.
There are a few other 2nd gen guys that went this route on the forum as well.
Old 01-17-2018, 09:25 PM
67camaro496 67camaro496 is offline
https://www.amazon.com/s/?ie=UTF8&ke...l_5mmip7ycu9_e Should be around 380 for 4 gallons with gun Remember you also need to prime before you lizardskin as it is a water based material.
Old 01-18-2018, 11:44 AM
Did it allow a lot of upward movement of the trans so the pinion angle could be set easily? That's the issue I'm facing now. I didn't bring my tunnel up as high as I thought so my pinion is angled too low.
Thanks for the information.
Old 01-22-2018, 01:02 PM
I'm sure you know it will be a little different for every application. Floor sag, transmission cross member, engine mounts, etc.
What I can tell you is that for me I have roughly 1 inch of gap. I'd think that is reasonable. Its also possible to bend the flange down around the base of the Holley Hump Panel to create even more of a gap.
Old 01-23-2018, 07:30 PM
You're right, every car is different. I also have half height body bushings on the front subframe to contend with. For $60, I think I'll give this piece a shot.
Thanks!
Old 02-02-2018, 08:50 AM
2/2: Update
Back from paint. Solid body mounts, sub frame, sub frame connectors, and rear suspension all installed. Wrapping up a few loose ends and then she goes back in to hibernation while my funds build back up.
Old 02-03-2018, 08:15 PM
