Old 07-19-2017, 07:27 AM
bonecrrusher's Avatar
bonecrrusher bonecrrusher is offline
I was having issues with my fuel tank system - and wanted to make dropping the fuel tank easier.
I decided to drop the transaxle out of the car - and with that gone - I was able to not only fix the fuel system - but I also decided to upgrade the clutch while I was in there.
The stock LS2 clutch only had 50k miles on it - but I decided to upgrade to the LS7 clutch while it was apart.
With the car torn apart - I also replaced the throwout bearing/slave cylinder, and installed a Tick Performance Speed Bleeder while I was in there.
Parts Used:
GM LS7 Clutch http://amzn.to/2r1DFDO
GM Input Bearing http://amzn.to/2rP79c2
Tick Performance Speed Bleeder http://amzn.to/2rZAT6Z
Powerbuilt Flywheel Tool: http://amzn.to/2u1PFuk
Please watch my full videos below about this swap:
Thanks everyone for all of your support!
Send me stuff!
Craig BonecrrusherSS
PO BOX 63
Denver, NC 28037
Purchase Stickers here:
https://goo.gl/JQTfC4
Follow me on Instagram: https://www.instagram.com/bonecrrusherss
Follow me on Twitter: https://twitter.com/bonecrrusherss
Like me on Facebook: https://www.facebook.com/bonecrrusherss
2005 LeMans Blue Corvette w/ T56 & Z51 & C6Z06 Brakes, Build Thread: https://lateral-g.net/forums/showthread.php4?t=27408
2005 GMC Sierra 2500HD - LLY - Allison
2014 Chevy SS - LS3 / 4 Doors
Old 07-19-2017, 07:55 AM
slimjim's Avatar
slimjim slimjim is offline
Originally Posted by bonecrrusher View Post
Hey Jim - that was probably me. I'm the only modified white SS in the area - at least that I know of.
You plan on going back to Mooresville at all?
Yeah sure do, I live in Huntersville but the in-laws live in Mooresville, If you remember, I'm the Aussie guy
NC
streamline 68 camaro
Build Thread here
Old 08-04-2017, 10:04 AM
I got rid of the last chrome parts on the outside of the car.
I looked into several options including painting the handles, wrapping them, and replacing them with non chrome Caprice PPV handles.
Replacing/painting the handles was going to be several hundreds of dollars - so I decided to wrap them in 3M vinyl.
To wrap the handles - all you have to do is clean the handles off - and get started.
Cut the vinyl to the length that you need - place it on the handle - and use you finger name to push in the edges where you are going to cut.
Use a sharp blade and cut the vinyl out - then remove the excess.
Cut the chrome button - and now you are done.
Parts used;
3M Satin Black Vinyl: http://amzn.to/2uAak9a
To view the full install please watch my video below:
I remember now! Nice to meet you!
Old 08-04-2017, 10:10 AM
I finally got the Mickey Thompson Drag Radials installed on the C6 Z06 front wheel.
I test fit the wheels - and the clear both the SS and the Corvette with no major issue.
The 305's stick out of the back of the SS a good bit - but they fit under the Corvette with no issue.
The 305 is a bit large for the SS and a bit undersized for the Corvette - but this was the comprise that I have to deal with to fit on set of drag wheels/tires on 2 cars.
Parts Used:
Mickey Thompson 305 35 18 - http://amzn.to/2ufcit1
C6 Z06 Front Wheels 18x9.5
To see the full video - please watch it below:
Old 08-04-2017, 10:23 AM
I am upgraded all of the exterior 194 bulbs on the Chevy SS with a set of Jtechnow 194 LED's.
The install was pretty straight forward - the LED's fit right in place of the 194 bulbs.
Parts Used:
Jtechnow 194 LED http://amzn.to/2uixo8E
Please watch my full video below for more details:
Old 08-04-2017, 10:28 AM
The clutch pedal was sticking last time I went to the drag strip. So I decided to swap out the clutch fluid - and filmed how to do it.
Swap the fluid 3 times or so - and you should be good to go.
Parts Needed:
Brembo Brake LCF600 Fluid http://amzn.to/2uFaUSj
Plastic Syringe http://amzn.to/2uJzUGy
Please watch my video below for more details:
Old 08-06-2017, 02:39 PM
Jay Hilliard's Avatar
PM sent!
Jay
Old 08-30-2017, 04:29 PM
I took the Corvette out onto the Road course/Roval at Charlotte Motor Speedway!
This was a charity event supporting the Speedway Childrens Charity - and they had the road course open. For $25 - you got 3 laps around the road course.
For the first section - I drove my Corvette.
For the second session - I rode along in my friends SS.
Please watch the full video below:
Old 08-30-2017, 04:40 PM
I took the Supercharged SS to Zmax Dragway for a Test & Tune!
This is the first time that the car has seen the strip with the LSA blower, and the drag radials.
