Old 01-05-2012, 10:10 PM
Sonar Chief's Avatar
Thumbs up
Originally Posted by KPC67 View Post
Great project, your car looks to be in very nice shape.
Thanks, if it wasn't for the CT weather rusting out the upper dash and cowl areas she'd be a pretty easy fix. But if it were easy everyone would do it!
I was looking at your 67 today, nice build, I like your outer wheel well stretch. My quarters are original and don't need replacement, so .... DSE mini tubs will have to get the room I need.
Michael
Old 01-06-2012, 09:27 AM
KPC67's Avatar
KPC67 KPC67 is offline
The mini tubs alone should be enough room. I now have over 15" (maybe unnecessary in your case). Research the tub install before you do it; I ended up doing mine twice because I was not happy with the room I had the first time around.
Kevin Carter
Old 01-06-2012, 09:56 AM
Thumbs up
I was looking into using AME and their 4 link under my 67, that way I will have a stronger foundation (factory rails gone) and should not have to cut into their rails. I emailed them about the mini-tub and clearance - no answer yet!
Michael
Old 01-06-2012, 10:46 AM
KPC67's Avatar
Michael
Thats a good idea.
I ended up with only 1/4" of frame rail left.
I don't have a good picture of it, I will take one tonight and post it up for you.
Kevin Carter
Old 01-06-2012, 01:46 PM
Unhappy AME 4 Link Update
Thats a good idea.
Yeah, that would be great to see. I just don't like the idea of cutting the frame rail and leaving a 1/4 inch? That can't be as strong as OEM!
Just got off the phone with AME and the 4 link frame is made to fit 335mm inside the wells (no cutting their frame), the drawback for me at least, I can't use my 12 bolt. The upper link mounts can't be welded on a 12 bolt, so .... guess I'll sell this one and save for a nine inch housing.
Michael
Old 01-06-2012, 01:52 PM
Ron in SoCal's Avatar
Hey Michael/Kev - I was also concerned about how little frame rail was left after the mini tub - even though we boxed the frame rail - so we ended up putting in 1/4" steel plate on the inside of the raii. There's a pic in this post:
https://lateral-g.net/forums/show...62&postcount=3
Of course, the AME rails avoid all this...
Ron in SoCal
69 Camaro in progress
Old 01-06-2012, 02:00 PM
Ron ... you bent up the 1/4" steel plate or you welded a plate on the inboard side of what was left of the rail? Can't tell from those pictures.
Thanks for chiming in.
Michael
Old 01-06-2012, 02:15 PM
Michael
Welcome Michael! We welded to the inboard side. I guess you could bend 1/4" steel plate, but I didn't see the need...
Ron in SoCal
Old 01-06-2012, 07:41 PM
KPC67's Avatar
Michael, I couldn't get any decent pictures tonight, my camera died.
I actually cut all of the frame out just leaving the sheetmetal on the inboard side of it, and bent up a 1/4" steel plate for the close out. I still think it will be plenty strong, and I plan on boxing it in once i get the car on a rotisserie.
Kevin Carter
Old 01-06-2012, 07:47 PM
KPC67's Avatar
Michael[/QUOTE]
It depends on what you want to do. I just bought a nine inch from DSE and the housings start around $900; or you can source one from a junk yard, the mid seventies trucks are a good place to start.
Kevin Carter
