1 Attachment(s)
I have several different length adjuster rods...looks like the short was put in the kit. Im not sure how that will effect the ratio...might increase it. I'll do some math in the AM. Let me know if there are any issues with it. I can send you the 4 inch bar. That should put the heim above the existing arm hole. It clears just fine with the AAW box on our test car. |
Yeah, its @ 2.66:1 thats gonna be tough....Shoot me his address and i'll ship out the 4" bar ASAP. That should be better on your leg. Ive run into a few funny holes where we had to weld up the hole and redrilled it. |
I'm running ls3, tko600, ls7 clutch kit.. Gm621 aluminum bell housing.. Would this setup works with your kit.. Any issues? Just want to make sure before ordering it.. Thanks
1758 N. 700th Rd Baldwin City, KS 66006 |
If you go with the full kit the slave that fits the TKO600 has shims to get the right placement match the clutch face. Flywheel choice MAY be a problem. |
You can search the NFW-1050 part number for applications then search for a performance version. Fidanza or Hays both have AL versions. |
| All times are GMT -7. The time now is 11:41 PM. |
