Closed Thread
Old 11-10-2013, 11:41 PM
Vince@Meanstreets's Avatar
Default Chevy pattern clutch master bracket
I had this proto typed for a 70 Camaro project we are building and I found with a few design changes will allow it to fit a few others cars. We test fit on a 1967 Chevelle, 1967 Camaro, 1970 Camaro and a 1969 Camaro. Slight modification required to fit 1st gen Camaros.
I'm having a bunch made to offset the cost and I am offering them for sale to anyone that could use it.
Its CNC machined from 6061 aluminum natural finish.
Mounts at the brake booster/master cylinder studs and x2 1/4" studs that go through the firewall. You must drill the 2 holes in the firewall.
Mounts most masters with a 2 1/4" bolt pattern. We use the compact Wilwood masters on all of our builds.
Prices start at $130.00 each and includes x2 5/16" studs, x2 5/16" nuts and x2 1/4 x 28 studs and nuts. Comes assembled and does not include master cylinder, hoses or pedal adapters.
We may put a kit together if these move well.
Dealers are welcome. We can engrave your company or project name on the flat section for that custom touch.
*Dealer and large quantity discounts available.
For more info please visit our site or facebook page.
Shipped via USPS from area code 94070
Vince Ortiz
Meanstreets Performance Fabrication and proto-typing
Design and Manufacturing
metal fabrication and defense systems proto-typing
"Cherry Lane Street Machines"
Service and Retail store
827 Cherry lane
San Carlos CA 94070
(415) 271-4839
www.meanstreetsperformance.com
[email protected]
[email protected]
Come visit us on Facebook
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 11-11-2013, 04:54 AM
Rick D's Avatar
Rick D Rick D is offline
Now that is bad ass!!!
Rick
Old 11-11-2013, 05:22 AM
cwylie cwylie is offline
Does it use the stock pedal??
Old 11-11-2013, 08:01 AM
garickman garickman is offline
Nice Vince! Looks like a killer piece.
Greg
Old 11-11-2013, 08:56 AM
Thanks for the interest guys.
Cwylie, yes, it uses the stock pedal. It also works with the Clayton pedals(70 camaro tested). You may have to redrill your pedal. From all of our test cars the stock rod hole lines up perfectly since it lines up with the factory clutch rod pass through hole.
I'll put a complete list of parts needed on my web store to make it easier to work out. I'm putting a kit together as we speak.
Dealer for
NEVER FORGET -11
Old 11-11-2013, 08:59 AM
NorCal72's Avatar
NorCal72 NorCal72 is offline
Vice, you can put me down for one. I need the rod too. I have the Clayton pedals. PM me if you want so $$$$ for that and the X member. Thanks
72 PT Camaro currently getting Quardralink suspension installed at Meanstreets Performance
29' Ford Roadster Ratrod
57' Big Window Chevy
Old 11-11-2013, 09:08 AM
Originally Posted by NorCal72 View Post
Vince, you can put me down for one. I need the rod too. I have the Clayton pedals. PM me if you want so $$$$ for that and the X member. Thanks
Great, i'll even install it for free!! I feel like you'll be getting the first full kit.
Thanks again for all the interest.
You might be seeing these available from another large manual transmission vendor!!
For more information please email us:
[email protected]
[email protected]
Vince Ortiz
827 Cherry lane
San Carlos CA 94070
(415) 271-4839
[email protected]
Dealer for
NEVER FORGET -11
Old 11-11-2013, 09:38 AM
no go nova's Avatar
no go nova no go nova is offline
Could you make one for 62-67 NOVAS?
Old 11-11-2013, 09:57 AM
as soon as I get a test car or a good outside and inside picture yes!!
Do you have stock man trans pedals?
edit: looks likes yes. You would just use the two top holes for master mounting. You could drill the two lower holes to run a nut and bolts through for more bracing.
Dealer for
NEVER FORGET -11
Old 11-11-2013, 10:14 AM
ma73z's Avatar
ma73z ma73z is offline
Damn, I just welded my DSE one to the firewall this weekend
That's a nice looking piece
Matt (amateur jack stand class)
73 Camaro in slooow process
69 Firebird LS1 4l60E
70 Chevelle 402bb tko600
Closed Thread
