-   -   Quickest Pro touring car? (https://www.lateral-g.net/forums/showthread.php?t=4327)
nitrorocket 04-29-2006 08:30 AM
Rocketman, what are specs on your car?? Tha is pretty fast! Those passes were on nitrous though, heh?
rocketman 04-29-2006 01:21 PM
spec's ??? not playin dumb,just what would you like to know?the list is long.
hiwayman 04-29-2006 02:55 PM
ROCKET holly crap im saying that is faaasssst could we have some insider info obviously power to burn i would like to know front shocks i.e90/10s size of the et streets also the rear shock combo, anyone quiker than that?
rocketman 04-29-2006 08:16 PM
27x10.5 et's (not radials)
full bmr suspension, tq arm,sfc,tube xmbr,a-arms.
hal dbl adj f/r
bear brakes
motor.
396 cube
usaul good stuff
callies crank
oliver billet rods
srp pistions 12.1
afr head began as 220's
cam s/r.26x/26x 6xx/6xx
sheetmetal intake
f.a.s.t
dynatech headers
4 in single ex flowmaster muffler
fogger nos sytem
t56-everything you can do to ne
spec clutch
it really pt.car and not a drag car.
rocketman 04-29-2006 08:21 PM
Originally Posted by rocketman
94 z28 bfg drag radial.10.26 @135 1.50 60ft,et streets 9.86@150 1.20 6o ft.
396 lt1,afr heads,comp solid roller,nitrous,6spd,moser 12 bolt
same amount of nitrous just changed tires.
ProdigyCustoms 04-30-2006 04:18 PM
im going to put 335 / 18s and bigger brakes on my street racer and it will be a PT car. It runs very low nines. I can use my ET streets right?
For specs,
404 CI
10:1 pump gas motor
a little squeeze
TH350
4.10 12 bolt
nitrorocket 04-30-2006 06:19 PM
I am not sure a road course would like a nitrous car with 4.10's! :_paranoid
ProdigyCustoms 04-30-2006 06:32 PM
4.10s are fine with a 7600 RPM motor, but i'll let someone grab the nitrous on the road coarse! Crazy sheot happens when you add 300+ horse on a roll.
I am being a bit fasicious (sp) with calling it a Pro Touring car, I keep threatening to do it and drive it on power tour. Put 18s on it, some 13" / 12" brakes, a stock deck lid and spoiler, remove the wheelie bars. Dirve it on the tour, pull into Gainseville, change deck lid to wing deck lid, put on ET street tires, put the wheelie bars on, and blast off a 8.99 to 9.30.
rocketman 04-30-2006 07:03 PM
the car has been faster,before i changed the suspension to a pro touring.
i drive it about 100-150 miles.
i have acouple set of wheels
chrome z06 wheels on 265/35/18 and 315/30/18
and
billet specialties on 265/35/18 and 295/35/18
hiwayman 04-30-2006 11:05 PM
frank could you post some pictures of the street car that thing sounds nasty
