-   -   Remote battery charging terminals (https://www.lateral-g.net/forums/showthread.php?t=52773)
Boss 5.0 04-19-2016 04:35 PM
Originally Posted by GregWeld (Post 635760)
Just to add my cents here ---- there's a HUGE difference between being able to "trickle" charge your PITA battery location - and being able to get a JUMP to that battery if needed.... and when it's needed it's never when your hanging out in your nice dry garage.
Remote battery JUMPER studs can be used to hook a trickle charger (I also vote for Ctek - they're the best period) - so if you're planing on something farirly permanent - this is an alternative.
There's MANY ways to mount these - and just as many locations....
http://www.summitracing.com/parts/sum-g1430/overview/
In a 55 Post I built for a buddy - I made a nice spot in the trunk for a cutoff switch and the posts - which was then upholstered over with a nice access panel.
And yes --- before it was finished up and installed for the last time - the red was changed out for a black (so one of each) but at the time of the build I was using what I had laying around for mock up....
http://i919.photobucket.com/albums/a...E/IMG_0717.jpg
http://i919.photobucket.com/albums/a...E/IMG_0722.jpg
By the way -- With the new electronics all having memory now that needs constant power -- I alway put a 3 or 5 amp fuse across the switch terminals so there's power even with the switch turned off. It's enough to run the memory and obviously not enough to start the car! LOL
http://i919.photobucket.com/albums/a...E/IMG_0742.jpg
Awesome ideas!! I'll be stealing that.
MtotheIKEo 04-19-2016 08:02 PM
Pretty much every OEM has jump start lugs under the hood that can be adapted for a custom installation.
