Just to stir the pot...:D I compared myself to a 91 ZR1 with A6's at my first and second event to see just how much better I got. I gained over 1.75 seconds on him from one event to the next. The first track was also better suited for me. Only changes......10mm less out back...20mm more up front....lighter wheels....r888'....probably a slightly better driver.
What you need to do well:
experienced driver sticky tires horsepower brakes light weight good suspension good setup proper gearing The track: 2 short straights 2 long straights Hard, straight braking zones at the ends of all 4 straights. long sweepers with some bumps can't see very far ahead, need to know the course well to properly position the car. JA had the most HP or very close to the most, the DSE 2nd gen looked very strong too. JA had wider rubber, best brakes and very experienced driver who knows that track. DSE cars were very well set up and strong running, well driven. Their 69 Camaro always seems to have a bit more understeer than the 2nd gen. I would expect them to do even better on softer rubber. Of all the cars there I was hungry for a chance to drive JA and the DSE 2nd gen. I was quite impressed with Jake and his 69 Camaro, great job! Matt got around the track well and I never did get over to take a look at what he's got "under the hood" The timers showed who had the best car/driver combo that day. We can speculate all we want but it's just guessing. I think it's a safe bet the DSE Camaro and JA would go even faster on stickier rubber. Jake would improve with more laps, Penny needed more shock & spring tuning and better brakes, hp was good but lower gears would have helped put the rpm's more in the power band. I wouldn't count leaf springs out totally, but who really knows? It would make handling the bumps in the sweepers tougher, but by how much in time? David |
i wish i had a racepak on as well, one will be ordered, where can i get the best deal on one steve?
i wish we knew, i am betting to say that i went as deep as anyone, as i had r888s and i had to have more corner entry and exit speed then you guys in order to be fast, and keep up. This is where a momentum track is a plus to different hp cars, because if you can drive you can run similar times to bigger hp cars. If we were at lets says watkins glen, i bet stielow and ryan would of been 4-5 seconds faster then me, as there are a few really long straights there. all in all it was a great time, and it will be fun to see what happens at the optima challenge. |
I guess you had to experience the carbon/ceramic brakes on JA to understand what I was trying to say.. they were really quite amazing. |
i hear ya steve, I bet they are unreal, as well they should be.
I will call ya. jake |
In my opinion to do well at a road race track you need experience. I started autoX then I did road racing. I did it all wrong. If you want to become a good driver start in a well sorted low output car, you have to learn technique and momentum. I started road racing in my '69 Camaro back in 1993. I had guts and was not afraid to "send it". Through this process I developed great car control skills. Looking back I'm glad I didn't crash more often. Later in life I started to drive low powered vehicles. Developing those skills helped me with the faster stuff. Attached is a data trace of a Corvette Z06 and a Solstice. One has 425 HP and one has 177 HP. If you look at the speed trace the cornering speeds are about the same. http://i439.photobucket.com/albums/q...5/Picture1.png When I do driver training at I force the guys to use the Solstice before we get them in the Corvettes. It also allows the guys to work there speed up and learn the line. I use a DL-1 box to data log. http://www.race-technology.com/description_8_956.html They are about $900 and are very easy to use. If you can get a fast guy to give you a data trace then you can compare your speed to his. If you don't have a faster driver then look at the data for smoothness and corner speeds. In general go fast in the fast places and slow in the slow places. It is all about courner exit speed. Learn to drive with the tach. You should know your speed at track out for each lap. Then work it up. Next work on you braking points. Pick a point the work it down deeper into the corner. Learn how to heal toe down shift. It is a lot of fun when you master it. But just getting out on track is the first step..:thumbsup: Mark |
Great advice!
I had an opportunity to drive a friends spec Miata, it was loads of fun, you can work on your lines and braking points and see the results by the higher tach reading at the ends of the straights. You can really learn a lot driving them. It just sucks to get stuck behind a car with more power that can't corner as well.
David |
I ran into a guy at Carlisle this weekend that was at this event and he said it was just awesome. I don’t remember his name he had a really nice blue 1st gen (IIRC a 68) with lots of DSE stuff. Maybe I have a pic somewhere. |
As Rupp say's, "I didn't build a track car". But, I have to say, Tom McBride from Bowler Transmission drove the H*ll out of the Fairlane. The Fairlane has original stock steering, upgraded stock suspenion and street tires. With Tom's driving and the motor that Rupp built, it was good enough for 31.127 in the autocross. :hail: I wish we would have had a 3 point harness to get timed on the Gingerman track. It was a Great Event. It was good seeing every one....
http://i252.photobucket.com/albums/h...ns/2ai1wqq.jpg |
| All times are GMT -7. The time now is 01:47 PM. |
