-   -   Goodguys 2015 Giveaway C10 by Scott's Hotrods (https://www.lateral-g.net/forums/showthread.php?t=44011)
Scotts Hotrods 12-27-2013 07:18 AM
Originally Posted by ccracin (Post 525060)
It's looking really good guys. One question, have you checked the turning radius with the foot area extended? My guess is you have really limited yourself unless you moved the cab on the chassis or moved the spindles forward on your chassis. I would really like to know if this works since I'm taller than average! :D
Again, looks awesome! :thumbsup:
The front wheels at full compression have plenty of room.When the front wheels are turned lock to lock there is plenty of room.The front centerline
of the wheels are moved forward 1 inch from stock.We do this on our c-10
chassis and our c-10 ifs kits.This will center the front wheel into the fender.
ccracin 12-27-2013 07:39 AM
Awesome, I figured you guys were on it! Can't wait to see more. Thanks for the reply!
tech@scotts 12-27-2013 09:06 AM
I'll shoot a few pictures so you guys can see the frame and firewall clearance. We set them up with the wheels set forward 1". As it sits right now, there is a ton of room between the firewall and wheels. I think the mock ups are about 3" shorter than the actual wheels/tires being used, but even with that, there's plenty of room.
tech@scotts 12-27-2013 09:09 AM
Originally Posted by 214Chevelle (Post 525068)
Looking good! I thought you guys were gonna do a tube chassis? Looks good either way though. :thumbsup:
I guess it just depends on what the definition of tube chassis is. We build some chassis's with round tubing, and build some with square tubing. We wanted our typical "off the shelf" chassis under this one to represent what would be typical if someone were to call an order one. I have a few round chassis cars I'll take a few pics of for you guys. They do look pretty cool.
tech@scotts 01-02-2014 11:34 AM
Right now the guys are setting up the ground clearance. The rockers are being trimmed and remade, ad the rear of the cab is being redone too.
http://i353.photobucket.com/albums/r...psc7586179.jpg
You can see just how much we are taking out of the rocker. Seems like a lot, but it'll really not be noticeable when it's all finished.
http://i353.photobucket.com/albums/r...psa9e217f1.jpg
http://i353.photobucket.com/albums/r...ps0e5927f5.jpg
tech@scotts 01-02-2014 02:03 PM
http://i353.photobucket.com/albums/r...ps7dcb404f.jpg
The body will sit level with the frame when it's finished. All said and done, it will give us our 4" of ground clearance that we need.
Here's a better view of the rocker. It'll be finished with a sheet metal cap and shaped correctly.
http://i353.photobucket.com/albums/r...ps2ddb2581.jpg
syborg tt 01-02-2014 02:23 PM
I can't wait to see this one finished.
tech@scotts 01-06-2014 03:33 PM
Not the best of pics cause the cars pretty low on the ground, but here's a pretty much finished rocker.
http://i353.photobucket.com/albums/r...ps6bf19c71.jpg
http://i353.photobucket.com/albums/r...ps509cf0f1.jpg
http://i353.photobucket.com/albums/r...ps83d409b4.jpg
tech@scotts 01-06-2014 03:34 PM
Well, the roof's off :)
http://i353.photobucket.com/albums/r...ps76985bf8.jpg
http://i353.photobucket.com/albums/r...ps3f868e77.jpg
http://i353.photobucket.com/albums/r...psda4ab56b.jpg
http://i353.photobucket.com/albums/r...psb87e836a.jpg
http://i353.photobucket.com/albums/r...ps1c123c80.jpg
Z06Joe 01-07-2014 07:40 AM
Absolutely love this style truck!!!! This is gonna be a bad ass build for sure!!! Gotta keep my eye out to win this!!!!
