You can see in the pic that the top corner on the door is rounded off from the factory square corner that comes on these doors stock.This adds a nice look when the drip rail is removed
Justin |
for those of you that are thinking it. It is the shadow of the lip on the pillar that make the gap look uneven although it is the same. |
When you do the final TIG welding on something like that windshield header, how long is your average pull ? Judging by the HAZ it looks like you only go about 1-2" at a time. Is that about right ? Just fill in between a tack or two ?
Oh man. I have my truck sitting outside my shop and wanna build it so bad now. This truck is sick
Awesome build guys
With that being said I don't necessarily stick to going tack to tack as sometimes that is to long of a pass. I mainly try to have short and very consistent heat affect zones, as this keeps the warping and pulling to a minimum and makes for a easier time metal finishing. Also, if the piece is cut in correctly and you have near zero gap as I do that drastically reduces warping along with my welding process. OK I'll stop |
The drivers side is coming along nicely..
http://i353.photobucket.com/albums/r...ps5aa9a8ef.jpg http://i353.photobucket.com/albums/r...ps9444add6.jpg http://i353.photobucket.com/albums/r...pse9acdfdc.jpg The rear peak is being removed and our roof kit is being installed. http://i353.photobucket.com/albums/r...ps875ef536.jpg http://i353.photobucket.com/albums/r...ps14f0b0f6.jpg |
http://i353.photobucket.com/albums/r...ps390c9858.jpg
http://i353.photobucket.com/albums/r...ps2b1c27c0.jpg http://i353.photobucket.com/albums/r...ps6f84e069.jpg The last picture gives you a good idea of just how much peak get's removed. |
DO you just spot every inch, grind, and then good to go or do you spot the entire seem? Thanks
| All times are GMT -7. The time now is 04:34 AM. |
