well here are some pics...I decided to make the ram air functional...so...it looks pretty good..the part on the car is a pattern, I will be making it nicer and making a mold for it. It has an upper part that closes down and seals to the lower....I have a few adjustments in gaps to make that I didn't have time or energy to get perfect. the wing has a third brake light in it under the yellow paint that lights up red.
THe stripes are actually really difficult to get right. they are an optical allusion. I originally made them with a 3/4 inch gap all the way through the s-curve...but it looked like crap from behind or in front of the car...so I ended up figuring out that you have to make the ends sweep gradually to a inch more on each end and when you walk around the car the stripes change according to your point of perspective and look exactly 3/4 of an inch all the way when standing at the front or back of the car.....weird.
I have a mold for the wing... my idea was that the car looked good at certain angles with a wing and not so cool at others...the ends mimic the tops of the quarters where they swoop up and the middle goes with the over all shape of the rear end with the bumper and heat shield all caring a commen shape.
This is the truth. As I started to go through the pictures, I was finding myself saying, that looks nice, oohh that looks nice, wow nice job on that. There are a lot of aspects that I really like on the car. Great job!!
'89 IROC-Z Turbo 3.8 5SPD
LS1 Brakes|Wilwood Prop Valve|LS1 Master Cylinder|Aluminum Driveshaft|LS1 3.42 Rearend|Adj PHB|Adj LCA|LCARB|Koni Struts|Koni Shocks|Adj Caster/Camber Plates|STB|10 Spoke SS Wheels|PHB Relo Kit|Adj TA|SFC|ARAP Based Prom|B&M Short Shifter|Underdrive Pullies|SMOG!|AIR!|Rag Joint!|Magnaflow|Ported Plenum|Misc Stuff
Thanks...it is really tough to know what to do without too much...my style is a little close. I know that but I worked with what I had and really enjoy making pieces that add to the look and add details. I am happy I went with my bros color choice..if I had my way originally it would still be a brighter color blue. I like color. Lots of silver or charcoal cars out there.
Oh yeah. How do I get in the lateral g car of the month runnings?
Sends specs, a concise summary of the build, and links your best pics to Jody aka 'camcojb' .
PM me if you have an other questions.
The artist formerly known as ‘cosmo mentis’…
