Old 07-13-2012, 08:09 PM
Z10ROD's Avatar
Z10ROD Z10ROD is offline
been watching this and of course trying to learn more.look great and good progress should make it in time . I was wondereing if i could get a pic of the tab welded to the subframe for the frame connector? oh I like flat colors just not white orange maybe ?
WWW.RODSCARCRAFT.COM
Old 07-15-2012, 10:09 AM
Stielow's Avatar
Stielow Stielow is offline
Engine harness, Dash harness and axle harness done. 80 hours work.......
Mark
Old 07-15-2012, 10:34 AM
nvmyss nvmyss is offline
Looks nice and clean.
Adam
69 Chevelle SS 396 < --Sold
67 Camaro
06 2500 Dodge Ram Diesel
93 Beretta GTZ
04 S60R ..Gone
Old 07-15-2012, 12:38 PM
coolwelder62's Avatar
Mark,What is the spacer for between the bellhousing and trans.Is the clutch setup thicker than stock.Wiring is extra clean.
Old 07-15-2012, 12:43 PM
Beautiful work on the wiring, I love details like that.
Old 07-15-2012, 12:52 PM
Stielow's Avatar
Originally Posted by coolwelder62 View Post
Mark,What is the spacer for between the bellhousing and trans.Is the clutch setup thicker than stack.Wiring is extra clean.
The spacer is .850" thick to allow the stack up to be correct to run a LS9 twin disk cllutch in front of a TR6060 with a 2002 style bellhousing. D&D Perfromance made the spacer and sells them.
I'm on the edge on the stock LS9 clucth but it drives great with very low effort and a great feel.
We build all the wiring from scratch. If you start with a GMPP LSA harness it is much easier.
Ryan Kuhlenbeck also wired Red Devil and we used that as a templete for this build.
The VanNus's (Dutchboys Restoration) is starting to shoot color tomorrow so I'm getting closer to getting the car back.
Mark
Old 07-15-2012, 01:14 PM
Rick D's Avatar
Rick D Rick D is offline
Mark the wiring looks great! Question for you how come you do not run a scatter shield?? So when are we going to see the color???
Rick
Old 07-15-2012, 02:16 PM
Jtomas801's Avatar
Jtomas801 Jtomas801 is offline
Hi Mark,
Did D&D performance do any tricks on the inside of the transmission, or is it stock from the factory? Also I see an oil pump for the trans, are you just using the fill and drain ports to remove the oil or is there some sort of spray bar in there?
The car is coming along nice hopefully I will be able to see it in person one day.
Thanks,
Jon
_______________________________________________
Jonathan Feltis
69 AMC Javelin - Back in Progress.
Old 07-15-2012, 09:33 PM
67XR7's Avatar
67XR7 67XR7 is offline
HEY Mark, where do you buy all your wiring blank plugs and etc.? I'm still using GM weather pack stuff but sometimes I need more then 5-6 slots.
1965 Chevelle, Pm me if interested in wheel tool rental
Old 07-15-2012, 10:11 PM
56pickup's Avatar
56pickup 56pickup is offline
Looks great Mark!
Tyler
