Old 08-10-2007, 10:25 AM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Default Staggered Shocks or Not???
I'm about to install the DSE mintubs and need some information. I have a '68 Camaro and want to set up the rear suspension with non-staggered shocks simply because I don't like the way the DSE shock crossmember looks in the staggered application. Is there an advantage to staggered shocks over non-staggered? I've heard that the staggered shocks help with wheel hop. Any thoughts?
Chris
Old 08-10-2007, 01:44 PM
I hate the angled shock mounting piece too. I really liked to know too.
63 Z06
Old 08-10-2007, 08:30 PM
philofab's Avatar
philofab philofab is offline
Default Staggered shocks
Staggered shocks do work slightly better in leaf spring suspentions to reduce wheel hop. However if you have any type of add on that controls axle twist (like slapper bars or such) they don't really have an advantage. What are you planning on running for rear suspention?
I like old junk and have ADD.
Old 08-11-2007, 07:14 PM
ItDoRun's Avatar
DSE 3" lowered springs and mini tub shocks. I'll eventually install a set of Cal-Tracs as funds become available.
Chris
Old 08-12-2007, 06:31 AM
67ragtp 67ragtp is offline
I have a 67 and set up the rear with DSE's rear crossmember, 3" drop leafs and the rest of there goodies in the non staggered configuration. I recently had a chance to anhialate my rear 315 bfg kd's. Im happy to say no wheel hop at all. I also believe that a well designed leaf spring will not wrap up as much and also carefully setting your pinion angle should help as well.
Rich
