Old 09-24-2007, 12:24 AM
SteveMcqueenRules's Avatar
SteveMcqueenRules SteveMcqueenRules is offline
Default Replacing floor pans
Has anyone Replaced their GM A-body floor pans or any really that could give me some tips to make it go easier or a step by step. Or point out a good explanation on the steps to ensure a good replacement with all the trick of the trade.
You're gonna be hangin' on for mercy when I get this sucker rollin'- FALFA
Old 09-24-2007, 01:36 AM
rubadub rubadub is offline
I have a few pages on my website about floor pans, might be something you can use.
Rob
"There are questions to be answered, and answers to be questioned"
Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything.
http://www.1969supersport.com
Old 09-24-2007, 08:23 AM
almcbri's Avatar
almcbri almcbri is offline
If your pans aren't completely rotted out, the best advice I can give you is to only cut out sections that are rusted/rotted. Cut the pieces from your new pans to fit the areas in the floors that you have trimmed out. (give yourself a 1-2" solid area of your original floor pans to weld the lip to. I always solid weld from the inside and outside, then grind, smooth with filler on the outside, and seam seal on the inside.
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 09-26-2007, 05:07 PM
well despite reading everything i could on how to do it i ended up not knowing a whole lot about it and just cut out the floor so i could put in the new goodmark full pan instead of just the rusted parts I really wish i had done it like you suggest would have saved me a lot of time. but at least i only did one side so far and can do it the easier way on the driver side of the car.
man i checked out your website rubadub and there is a ton of great info! thanks. the detailed pics and info about the floor pans will be such a help to me. And it is all very clear with great pics and descriptions! I have been worrying about how to do this for a while. Never done a project like this and afraid of screwing up. but with your website I think i can do it. Thanks again!
Old 09-26-2007, 06:08 PM
bucks69 bucks69 is offline
Rubadub is KING of technical how-to guides!!!!!
Old 10-07-2007, 02:50 AM
Thanks guys
