Old 11-21-2007, 06:04 PM
69 b5blue's Avatar
69 b5blue 69 b5blue is offline
Default overdrive for big block mopar
Does anyone have any idea's for an overdrive transmission for big block mopar 'b' body cars
1969 dodge 383 727 3:23 lowered 18'' coys
Old 11-21-2007, 06:21 PM
auto or manual trans?
Old 11-21-2007, 08:24 PM
69 b5blue's Avatar
auto please
Old 11-21-2007, 08:29 PM
rjsjea's Avatar
rjsjea rjsjea is offline
Default manual or auto?
Depends on power output obviously.
Auto--A518 or 727+gearvendors, SMR transmission
4l60E, Keisler
4l80E, SD concepts, or Wilcap for an adapter
Manual--5spd--Keisler, Wilcap for apapter, Quicktime bellhousing and others
6spd--Quicktime for bellhousing or Wilcap adapter
4spd overdrive--Passon Performance (aluminum/lightweight)
Im in the same boat, looking for OD options for a Dodge Demon. These are some of the ones I have found and looked into. This is totally dependent on budget/modifications to trans tunnel/power of engine etc...
Old 11-21-2007, 09:13 PM
69 b5blue's Avatar
thanks for the info. Im like you. budget for 1. keisler would be ideal but $3400 I do have everything for a four speed but more work. witch is no big deal. I have a 383 that is been warmed over. I'm guessing H.P around 400
Old 11-22-2007, 12:16 AM
rjsjea's Avatar
A 6speed conversion kit is supposedly coming out soon from Weir Hot Rod parts for us mopar guys. I talked to him last week and "it's in the works" for the winter.
Old 11-29-2007, 11:24 AM
6D9 6D9 is offline
GV overdrive............period
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
Old 11-29-2007, 01:12 PM
JohnC JohnC is offline
DITTO
Old 11-29-2007, 06:27 PM
69 b5blue's Avatar
allright this is what I found
http://www.gearvendors.com/hrdodge3s.html
this i'm looking at about $2'500
Old 11-29-2007, 06:30 PM
69 b5blue's Avatar
or this overdrive.
http://www.keislerauto.com/mopar/tra...omatic-4sp.asp
about $3'500
