Old 09-14-2008, 06:29 PM
Project_Gotham Project_Gotham is offline
Default Ford 9' Tech needed
I feel foolish asking but what are these forums for right???
I have never been a "rear-end" guy. Well on cars at least
What is a ford 9' 3rd member composed of? I need to complete my narrowed Currie H-D 9' housing and I want to use the truetrac system. What all components do I need to have one built?
I know the easy way would be purchasing a "crate" 3rd member. But I'm doing my research and trying to save. Thanks fellas.
--Mark Stielow Wannabe--
1968 Camaro SS
1969 Camaro SS
1969 Camaro LS7
2014 Chevrolet SS Sedan
Old 09-15-2008, 09:39 AM
badmatt's Avatar
badmatt badmatt is offline
case (caps)
gears
pinion support
bolt's
spool, locker, open diff what ever...
bearings..
and adjusting Nuts or sleevs what ever you want to call them.
they are probly the easiest diff to build and work on due to NO carrier shim's only shims in the whole diff are the big ones used between the pinion support and the case.
97 Sonoma "NERA": Pile O Sh*t. Literally.
