Old 08-08-2008, 02:30 PM
aany001's Avatar
aany001 aany001 is offline
Default why car does not sit level what gives????
Man do I have problems....I will try to explain it as best as I can.On 69 camaro I assembled my shortened rear end with brakes, half inch spacers then wheels installed and slipped it under the car with a DSE mini tub kit as well as DSEs 3" dropped leafs.My rear wheels are 18x12 with 6.125 backspacing.When the car is on the ground the left side sits 3/4" higher than the right side.Next issue is the left tire side wall is 1/4" away from the quarter panel while the right side has almost an 1" from the quarter.Here comes the kicker...you would think just loosen up the adjustable leaf perches and walk the rear end over 1/2" and problem solved but as soon as I move the diff a tiny bit the left tires inside sidewall sits the leaf spring!!! I have as it sits now 1/4" between the left inside sidewall to the leaf spring and 1/2" on the right inside sidewall to leaf spring.Man am I stressed out.......please help!
Steve
Old 08-08-2008, 04:15 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Wow..I'm a little stressed out after reading that!
I wouldn't worry to much about the 3/4" diff in height at this point. Seems to be a common problem when installing new leafs. It drove me nuts trying to get mine right. Biggest mistake is putting the car on the ground with all the nuts and bolts tightened. It also could be that one leaf has a different arch than the other.
The other issue is confusing...clear as mud kind of thing. Did you use the DSE Offset Shackles? Do you need them?
Keep the faith. Someone here has a solution.
Curtis
Old 08-08-2008, 10:35 PM
aany001's Avatar
I used the complete DSE mini tub kit.About the leaf springs...... its almost as if the leaf springs and the rear end need to move 1/2" over towards the pass side.
please help!
Old 08-08-2008, 11:21 PM
David David is offline
Have you contacted DSE for tech help......
Old 08-09-2008, 01:29 AM
zbugger's Avatar
zbugger zbugger is offline
Any way to share some pictures? That would help a lot, actually.
Lost in a hopeless world on a path that wanders aimlessly and endlessly... As if it really even mattered.
Old 08-09-2008, 04:41 AM
67ragtp 67ragtp is offline
I dont think your problem is all that bad, move the right side over towards the left 1/8 inch that gives you 3/8" on both sides. Check the yoke center and pinion angle and weld it. When I did my 67 mini tub set up Kyle had no problem with my 1/4 clearance between the tire and spring. I chalked my leafs and did a slalom test in a parking lot and got real agressive left to right , side walls didn't touch. It sounds like your backspace would have been nice at 5.5 inches(no spacer) instead of 6.125, a 1/2" spacer is a lot in my opinion, make sure the studs are long enough to get a good bite on the wheel.
BTW- Im curious what was your axle flange to flange dimension?
Rich
Old 08-09-2008, 06:56 PM
aany001's Avatar
I will try to post some pics of the problem areas tomorrow.
Old 08-11-2008, 06:48 PM
aany001's Avatar
all these photos are from the rear of the car...in these next 4 pics it is of the left rear wheel of the outer tire sidewall to quarter lip which is 1/4" and inner sidewall to leaf spring is 1/4".
Old 08-11-2008, 06:59 PM
aany001's Avatar
these next four are the right rear with 3/4" from outer sidewall to quarter lip clearance and inner sidewall to leaf spring has just under 3/4" of clearance.
Old 08-19-2008, 05:48 PM
aany001's Avatar
anyone else run into this problem???
