Old 01-11-2009, 03:35 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default Broken fender bolt won't come out!!
So I need your guy's advice on how to get a broken fender bolt out. I tried welding a nut on the end...no luck. Kept breaking off. The weld didn't want to stick all that great. I've drilled the center out and used two different type of easy outs...no luck. I've soaked it with liquid wrench...you guessed it...no luck. Today I used an oxy torch and heated the area up around the bolt and tried the easy out's again...no luck. Any one have any suggestions. Here's a pic:
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 01-11-2009, 03:53 PM
Your going to need to drill it all out and either Heli Coil, Tap to the next size, or weld a new nut in the hole.
Old 01-11-2009, 04:19 PM
E.rodz's Avatar
E.rodz E.rodz is offline
being is you already have a hole just drill it out to letter f drill or 1/4 drill for 5/16 -18 tap.or take a nut round the points down now drill the hole big enough to place modified nut into an weld it in.nothing to this stuff.
my name is Eric Hokenson I have a dream of building ten of the coolest hot rods out of my home shop wish me luck I am going to need it! - more pics on my web site www.erodzcustoms.com this is just for fun and i am NOT looking for any more work!
Thank you supporting sponsors! without you guys there is no way I could do this myself !
Modern automotive performance,Ring bros.,Yank convertors,extreme drive systems,Cj tunes,race coatings stainless works,Modern Automotive Performance.all of these shops have the experience to get your car to the top.
Old 01-12-2009, 07:09 PM
scherp69's Avatar
Thanks guys. I think I'm going to end up just tapping it.
Mike
New Gen Splitters
LS3 and TKO600
