Old 01-24-2009, 11:20 PM
jcal87's Avatar
jcal87 jcal87 is offline
Default Kit car Camaro VS. buying all new body panels?
I just picked up a project car and its runs perfect looks great to the uneducated eye. but its got some bondo on just about evey piece of metal there is. so my question is If im building a pro touring when do you justify to spend thousands on body work and new panels or but a kit camaro for around 12 grand? by the way its a 68 ss (i think... apparently theres no way to tell?) heres the you tube link to the car
https://www.youtube.com/watch?v=neCCBVy8oy4
Old 01-25-2009, 02:52 AM
jst8a5.0's Avatar
jst8a5.0 jst8a5.0 is offline
Because you still need stuff like window regulators, hardware, etc, and it still needs to be prepped and painted. And I think you can tell a 68 because they put side markers in them.
Micah Prudhomme
Concept Fabrication, LLC
Shop page:
http://www.facebook.com/ConceptFab2006
Shop channel: https://www.youtube.com/my_videos
Old 01-25-2009, 04:10 AM
We are finisheing a Dynacorn body right now and as Jst8 mentioned there is a aweful lot of little things you have to buy if you do not have a donor car. There are a few things you cannot buy. For us to thrash a original body, it will have to be really far gone. Replacing out sheetmetal and floors is common practic for us. Even cowl tops. When you get into needing full rockers, windows frames, frame rails, etc, may be when it is time to consider a new body.
Frank Serafine
Old 01-25-2009, 04:12 AM
Smack_talker's Avatar
Smack_talker Smack_talker is offline
I think he means that there is no way to tell its a real SS, not that its a 68.
R.I.P Jenna Weaver, my "Little Peanut" 01-18-07 to 01-30-07. Thank you for 13 days that I will NEVER forget.
Old 01-25-2009, 06:51 AM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Just because there's bondo, doesn't necessarily mean that the panels are bad. You really need to get the car to metal before you can make that call. It also depends on how far you want to go with it. What condition are the floor pan and trunk pan?
Chris
Old 01-25-2009, 12:51 PM
jcal87's Avatar
trunk and floor are almost perfect very little rust. but one part of the trunk does confuse me a little when i lift up the carpet there seems to be like a piece of sheet metal that goes across the trunk but drops off before you get to the quarter panel and wheel tub im not sure if this is normal or not.
Old 01-25-2009, 01:08 PM
jcal87's Avatar
Oh and 3 out of the four window cranks dont work.
Old 01-25-2009, 09:42 PM
jst8a5.0's Avatar
Oh yeah? I always thought the "SS" was a dead giveaway it was a true SS.
Micah Prudhomme
Shop page:
