Old 06-08-2009, 01:01 PM
GM Muscle's Avatar
Default booster from camaro to chevelle
im buying a chevelle that has manual 4 wheel drum brakes. my camaro used to have power 4 wheel drum brakes. will the camaro master and booster bolt up to the chevelle? i plan on going to four wheel discs with the chevelle but im trying to keep it down to one project at a time and this would be virtually free. thanks in advance
brantley
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 06-09-2009, 12:56 PM
GM Muscle's Avatar
still a mistery...
Old 06-09-2009, 01:44 PM
stealth71 stealth71 is offline
Probably not worth the time and effort. Just save up for a disc brake conversion and change it out then.
Old 06-17-2009, 05:16 PM
C5 Longroof's Avatar
C5 Longroof C5 Longroof is offline
I hear your financial woes my friend....
I have done this exact swap and I am happy to say that it does work...And what a HUGE difference it will make in driveability, if you don't have a radical, no vac. camshaft though...Of course going to disc brakes would be the safer, even BETTER choice, but for now, swap that stuff over!!!...
Make sure you change the position of where the pedal interacts with the shaft that moves your master cylinder piston...
Happy "better" braking...
Rick
