View Poll Results: Which engine to go with?
GM 480hp LS3, still need wiring 10 24.39%
GM 525hp L92, still need wiring 19 46.34%
Mast Motorsports 480hp LY6, includes their controller 7 17.07%
Give me an idea on another set up 5 12.20%
Voters: 41. You may not vote on this poll
Old 05-08-2009, 12:16 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default Which engine to go with?
So I am undecided what engine I should go with. I'm currently building a pro-touring 68 Acadian (exact same thing as a Nova for those that don't know). It will be used 99% of the time on the street with the goal of getting it to the track one day to see how it does. I want a motor that will be as close to or over 500hp as possible. I know I want to do a LS conversion, and here's what I been debating about lately. Keep in mind these are Canadian prices.
Choice one is the GM 480hp LS3 crate engine. I can get it for about $6800 CDN. Engine is all aluminum and comes with car intake. Still would need to get a wiring kit for it.
Choice two is a L92 with cam and intake upgrade putting it to about 525hp. Will run about $7800 CDN. Engine I believe is all aluminum and has LS3 heads. Still would need to get a wiring kit for it.
Choice three is a Mast Motorsports LY6 with 480hp. Can get it with a car intake upgrade for about $8500 CDN. Engine has a cast block with LS3 heads. Comes with the Mast wiring controller which is apparently really easy to hook up. Engine is already broken in on the dyno.
Choice four...help me out if you think there's a better option for around the same pricing.
If you do make a selection or have an opinion, I would really appreciate it if you told me why you think I should go that route. I don't know much about LS engines at all so this is all a learning experience and any info would be greatly appreciated.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 05-08-2009, 01:18 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
I've gone through a similar process and settled on the GMPP 376/480 with the GMPP wiring harness and the GMPP accessory kit w/o air. The harness is plug and play, comes complete with electronic throttle (aka gas pedal), MAF sensor, wide band O2 sensors, bungs, etc. and is programmed by GMPP for the LS3 with the hot cam installed. With respect to the other tuners out there, this is not GM's first time at the LS3 tuning party.
I also went with the GMPP accessory drive because it was cheap and engineered for daily use in the Corvette. Finally I got the Kwik Sanden AC compressor adapter kit for use with the Corvette accessories and I think I should be good to go. I may upgrade the accessories at some point in the future, but this car is already costing cubic dollars.
Oh, a 2 year warranty on the engine also isn't too shabby assuming GM survives.
Old 05-08-2009, 03:01 PM
Sherp69 Check with Frank From Prodigy he had some LS engines for sale even an LS7. Not sure what he's got left but worth a try.
Wayne
Old 05-08-2009, 03:24 PM
130fe 130fe is offline
Post
Here's another option for you: http://cgi.ebay.com/ebaymotors/GM-L9...1%7C240%3A1318 The L98- LS2 with LS3 heads and accessories, harness and some other misc stuff. Swap in another cam and you could easily have 500 hp (crank) for less $ than the others.
I bought an L92 crate and am now try to decide whether or not I am going to keep the VVT or not. The one good thing about the mast stuff is the wiring and alot of the bugs are worked out for you. Just depends on how much power you want.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 05-09-2009, 02:04 PM
MattO MattO is offline
I'm working my way around an L92 right now. Speartech would probably be the first company I would call for a controller and harness.
"I should have just started smoking crack. Its just as addicting and WAY cheaper..." --unknown
Old 05-09-2009, 07:24 PM
scherp69's Avatar
Thanks for your input so far guys. I have talked to Frank a few times about engines already and the L92's he has. That's one of the one's I'm debating about with an intake, cam and lifters upgrade. I'm sure if he saw this thread he's probably shaking his head and going "here we go again"
To be honest, the whole LS thing is completely new to me. I don't know what the differences are. I guess what I'm trying to figure out is what makes the L92 a better choice than the LS3, or vice versa, or why's the LY6 a bad choice, etc. I do know that a complete aluminum will definitely keep the weight down. One question I have about the L92....what is VVT and why is that desirable or is it even something I want??
Originally Posted by Sparky67 View Post
JThe pricing that you are receiving on the LS3 seems to be a bit high.
Really??? So far I haven't found anyone cheaper. Summit wants $7800 US ($8900 CDN), Jegs wants $7700 US (about $8800 CDN) and Pace Performance wants $6500 US (about $7500 CDN) so really I can get it for about $700 cheaper than any of the big name sellers. As stated I can get it for about $6800 CDN so about $5900 US. If I found it even cheaper, that may make my mind up. The 430hp version seems to run about $450 - $500 cheaper at most places.
It's funny when I was going to go with a good old sbc I had my mind made up, then I had to come on sites like this one and see what the LS engines can do Any other input would be greatly appreciated.
Mike
New Gen Splitters
LS3 and TKO600
Old 05-15-2009, 08:01 PM
c3corvette77 c3corvette77 is offline
Have you considered the GM 376/515? It's a 515 HP LS motor with a carb intake manifold. For some reason I can't find pricing, sorry.
http://www.gmperformanceparts.com/En...1225&engCat=ls
Old 05-16-2009, 08:27 AM
Pantera EFI Pantera EFI is offline
Default L-92 VVT/LS-3 intake
My choice would be a "take-out" 2006-2009 L-92 VVT (Escalade), about $2000 ???.
Then install the LS-3 intake with a DBC 90mm air door. (about $500)
Use the WaterThunder EMS, harness, calibration, ($2250)
This will "bench dyno" at 480 SFHP, or over 500 with cam change. (keep lift under .550" with stock springs)
All this for under $5000 USD, a bargin !
Lance
Old 05-16-2009, 10:49 AM
holschen's Avatar
holschen holschen is offline
Default bigblock aluminium
4.5bore with 3.5stroke titanium wristpins and rods heads to go with and titanium valves and retainers
finish up with a tci 6speed aut
my 2 cens
camaro69-l92+6l80e-
speedtech(LCA)-ats Street-Comp AFX-unisteer r&p-VariShock
camaro 5gen rear
Hydratech Brake Booster
movit brakes 380mm 6piston front- brembo 465mm 4piston rear
275/30-19 front-325/25-20 rear
19x9f 20x12r cray scorpions
Old 05-22-2009, 08:18 PM
CamaroPat's Avatar
CamaroPat CamaroPat is offline
Default Just a suggestion...
For comparable money, you could run a fairly mild LS engine of some sort (around 400hp) and throw on a supercharger, or electronically boost controlled turbo setup. Turbo kits are still pretty expensive, but the potential is amazing. If your budget needs to remain realistic, there are some fairly economical supercharger kits available. The upshot to this decision would be that if you equipped your supercharger with a quick change pulley system, you could extract a few more pounds of boost for track use or use with higher octane fuel (whether it's race gas or e-85) and with a ten minute pulley swap you'd be back to having very streetable engine. I was going to use a Magnacharger on my '99 TA before I got rid of it. I raced a guy who had one and I lost MISERABLY, easily 1.5/2 seconds in a quarter mile. I talked to him for a few minutes after my beating and he was very pleased with the manners and reliability of the setup. There are other centrifugal supercharger setups worth considering as well. Just a thought.
Great success rarely comes without the risk of great failure. '81 Camaro, 350, Edelbrock 750, headers, 4 speed, '97 Buick Park Ave Ultra, Supercharged 3.8L V6
