Old 05-18-2015, 10:07 AM
1Bad68Cat 1Bad68Cat is offline
Default My 67 Cougar Build
I started this build a couple years ago. It is a slow build. And I mean really slow. I have posted some pics of the things I did in other threads but figure I'll include them here.
I started with this:
Old 05-18-2015, 10:08 AM
As I mentioned before I did some small things here and there. Here are a few pics of the front brakes I will be installing.
I did some prelimnary mock up with the coyote engine.
Along the way I built an engine lift fixture because I didn't feel comfortable with the lift brackets supplied with the coyote engine. I can see them bend as I lifted the engine. Getting the CG right also proved to be cumbersome with the supplied lift brackets.
Old 05-18-2015, 10:09 AM
To date, I have mostly installed the front suspension. Still need to weld upper control arm mount gussets, top coil over mount, and and the down tubes. I'll tie the gussets, coil over mounts, and down tubes together.
Old 05-18-2015, 10:20 AM
DavidBoren DavidBoren is offline
Coyote in a cougar, I don't see anything wrong with that. And it looks like you've got a good thing going with your front suspension.
What are your plans for the rear? Full floater 9" with a decoupled 3-link? Built 8.8" with an offset 3-link? Cobra IRS?
Old 05-18-2015, 10:34 AM
I have a 9" already, but I plan to convert it to a semi-floater similar to what speed tech offers with theirs that use the c6 SKF hubs. I will be using a SRT8 setup instead because the wheel bolt pattern is similar to a Ford. I'll redrill the hubs for 5x4.5 since the SRT8 bolt pattern is 5x4.527. That way when I need to replace rotors I can go to the parts store. The holes are oversized in the rotors that I can use the 5x4.5 bolt cirlce.
Old 05-18-2015, 01:04 PM
Justin@EntropyRad Justin@EntropyRad is offline
Default That frame...
is beefcake! Kudos for the Coyote swap
Old 05-18-2015, 05:23 PM
Great project. This is going to be one fun ride! Nice job on the lift fixture.
Old 07-06-2015, 03:59 PM
Small update. Fabbed up and tacked motor mounts in. Hope to finalize engine placement, then install both engine ans transmission so I can fabricate the transmission cross member.
Old 07-07-2015, 09:01 AM
bonecrrusher's Avatar
bonecrrusher bonecrrusher is offline
What car did the 6 piston brembo setup come from?
2005 LeMans Blue Corvette w/ T56 & Z51 & C6Z06 Brakes, Build Thread: https://lateral-g.net/forums/showthread.php4?t=27408
2005 GMC Sierra 2500HD - LLY - Allison
2014 Chevy SS - LS3 / 4 Doors
