Old 08-03-2011, 12:46 AM
69blackwhss 69blackwhss is offline
Default Help on steering parts
Ok guys I have a 69 Camaro an am going with ride tech /air ride upper an lower control arms with coil overs an the truturn kit on the front I have a new steering box that is stock for a 69 Camaro an I was goin with the Dse Hotchkis 515-CHESTR001. Here's a link hope it works http://www.jegs.com/i/Hotchkis/515/CHESTR001/10002/-1 what else do I need to get to be done with my steering I know I am missing like two parts r so any info would be great thanks Jason
Old 08-03-2011, 07:57 AM
Blake Foster's Avatar
i think if you look at the Truturn kit it includes all those parts.
Blake Foster
www.speedtechperformance.com
Old 08-03-2011, 04:42 PM
JustinB's Avatar
JustinB JustinB is offline
Center link and pitman arm for a stock application. I think Blake is correct. The Truturn kit comes with all those parts you are ordering from Jegs.
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
Old 08-04-2011, 03:59 AM
No I just wanted to let people know what I was trying to say an what parts I would be going with
Old 08-04-2011, 07:24 AM
JustinB's Avatar
What? You lost me.
Justin Butler
Old 08-04-2011, 11:57 PM
What? You lost me.
Am not ordering anything from jegs I just ordered my truturn but I think there r mort steering parts that I need to replace but am not sure what they r am just hoping someone on here can tell me what else I need to get so I will have it all when am under the car u know. Sorry about the mix up Justin
Thanks jason
Old 08-05-2011, 04:38 AM
Supporting Vendor
Jason,
Understanding:
First, a little punctuation would go a long way with our crowd. Most of us grew up in a time when we were taught in school proper grammar and not "texting code". For us it's very difficult to understand a run-on sentence. Not busting your balls, but I though I should try to help as you seem to loose people on both this forum and Pro-Touring.
Steering:
You can use all the stock steering parts with our TruTurn if they are in good working order, no need to replace them. If they are worn out, or you just feel more comfortable replacing them all at once you will need the following stock items in addition to the TruTurn kit:
-pitman arm
-idler arm
-drag link (the drag link is just a large chunk of steel. So long as the mounting holes are good and not damaged you will be able to re-use the stock part)
Skunk Werks
Ridetech
www.ridetech.com
Old 08-06-2011, 03:13 AM
Thanks! Sorry but I don't have alot of time! I jump on here on my breaks and ask the questions. I just payed 3800 for ur coilover kit an truturn. I was just wanting to redo my steering all together. But ill look at the syockbparts when am changing over to coilovers. Hope that's a little better. Jason
Originally Posted by marolf101x View Post
Jason,
Understanding:
Steering:
-pitman arm
-idler arm
