Old 02-07-2013, 11:09 PM
black67malibu black67malibu is offline
Default LS2 with LS6 manifold fuel system
since I have the LS6 manifold on my LS2 with what looks to be a FPR built into the stock fuel rail system. Does my fuel system still need to use the corvette fuel filter/pressure regulator in it? Also, does someone make a kit thats a little more cost effective than a SS line stylde? So far I found the fuel filter/pressure regulator at speedway for $69 and just need lines ect. I have a used Ricks hot rod shop tank. Thanks, Tyler
Old 02-08-2013, 04:58 PM
That's not an FPR on the fuel rail. You also only have one line on that fuel rail. So yes, you need the C5 fuel filter to both regulate the pressure and provide a return to the tank. I can't help with your other questions, sorry.
Old 02-08-2013, 08:15 PM
Thanks for the response. I ended up finding a company called nasty performance and they provid a kit with all the parts and hose for $350. Im gonna go this route.
Old 02-09-2013, 07:24 AM
Good job!
