Old 01-29-2013, 11:11 AM
Firebird-Geek Firebird-Geek is offline
Default Temporary "Roller" wheels for project
I am on the hunt for some temporary wheels that I could mount while doing paint and fabrication... car would not be driven with the wheels... just Rolled around.
I am still doing the quarter panels and other fixes so I would rather order my final wheels when I can get some accurate measurements after everything is finally welded together. Plus, I would rather weld/grind/paint the car without the expensive final set of wheels and tires on the car.
Problem... I need 17" or above to clear the Wilwood brakes, plus 1/2 wheel studs.
I figured it would be easy just to go to a junk yard and get some... WRONG. Hardly any vehicle I find uses something that would work. I did manage to track down some 5th gen Camaro 18" steel wheels.. with 245/55/18 on them. They are almost new and the guy wants $400 for everthing. I REALLY hate spending that much on something that will not stay on the car, for this is a budget build.
QUESTION: They are a 28.6" diameter.. will they fit? Anyone else find a better/cheaper fix?
Thanks for any advice...
1967 Firebird Convertible
Jarrod
My Build:
https://lateral-g.net/forums/showthread.php4?t=32878
Old 01-29-2013, 09:48 PM
Apogee Apogee is offline
I'd probalby just pull the calipers and rotors if needed, then use 14's, 15's or whatever was laying around.
Tobin
KORE3
www.kore3.com
Old 01-29-2013, 10:11 PM
FETorino's Avatar
FETorino FETorino is offline
I would bet the tire height may be a problem. I looked on Craigslist and found a set of Stock corvette wheels with some slicks on them for $325. They have been putting 17s or bigger for a while, so older scuffed up Corvette wheels are out there.
Late model space saver spares are another good option. I've seen a lot of guys use those.
Rob in SoCal
Old 01-30-2013, 06:30 AM
Wissing72's Avatar
Wissing72 Wissing72 is offline
it looks odd but maybe this will help? 50.00 or so in plywood and a jigsaw...
Chris
70 Chevelle. Roadster Shop Chassis, The shop llc/ Jon Lind interior LS3/6speed. Thanks to Precision Classics and Collision Eugene, Or. http://precision-classics.com/
Build thread:https://lateral-g.net/forums/showthread.php4?t=39517
Old 01-30-2013, 06:32 AM
NvrDun71 NvrDun71 is offline
04-06' GTO spares if you can find them for a good price, which is getting harder to do these days
71' Nova - LY6, T56
Old 01-30-2013, 06:40 AM
Gaslight Gaslight is offline
I have these for sale if you are interested.
http://inlandempire.craigslist.org/pts/3561041377.html
Jake
1973 Nova SS
Old 01-30-2013, 06:45 AM
randy randy is offline
if the 5th gen wheels are new then buy them. once you are finished resale
Old 01-30-2013, 11:55 AM
Those are sweet! ...and you can stack them up and store them anywhere when you're done.
Tobin
KORE3
www.kore3.com
Old 01-30-2013, 12:59 PM
NOPANTS68 NOPANTS68 is offline
I ran into the same issue. I just pulled the calipers and bolted on some slot mags I found for 50 bucks. I'm running C6 Z06 Kore3 gear on a chevelle.
1929 Roadster Pickup
1961 Chevy Parkwood Wagon
1956 Chevy 210
Smithcraft Collision and Restoration
Newcastle , CA
Old 01-30-2013, 04:02 PM
intocarss's Avatar
Why not make something like these?
