Old 05-22-2013, 06:14 PM
huggerz's Avatar
huggerz huggerz is offline
Default What fuel line with a LS?
Hey guys I have a 69 Camaro that I am installing a LS1 in. I am at the point where I need to get the fuel to the engine. I have a Spectra tank with a internal fuel pump, and plan on running the Corvette fuel filter. My question is this. Can I splice into the factory 3/8 steel fuel line and use AN fittings, or do I have to run all new line? Will the factory fuel line handle 60 psi of pressure? I really don't wanna run braided hose or the plastic Dorman stuff. Whats everyone doing?
Aaron
69 Camaro
Old 05-22-2013, 07:09 PM
The factory steel line as long as it's in good condition would be fine.
Old 05-22-2013, 07:20 PM
huggerz's Avatar
Awesome! A couple of adapter fittings and I will be good to go. Thanks Jody!
Aaron
69 Camaro
Old 05-22-2013, 07:24 PM
You're welcome Aaron.
Old 05-23-2013, 09:05 AM
NvrDun71 NvrDun71 is offline
Inline Tube will add AN fittings to stock replacement pre-bent hardlines. That's what I'm planning to run on my swap, give them a call for more info
71' Nova - LY6, T56
Old 05-23-2013, 09:47 AM
hifi875's Avatar
hifi875 hifi875 is offline
I am currently running a ls that I just switched over from carb to fuel injection(Holley Terminator). I bought a tanks inc. setup with walbro pump and new sending unit. I didn't want to mess the old factory tubing and since I had to do a return anyway I just ran all new lines with Earls pro-lite lines and ano-tuff ends. Everything is black, looks great and I didn't have to rig this or adapt that to make everything work.
http://www.holley.com/350004ERL.asp
http://www.holley.com/AT304620ERL.asp
this is the kind of stuff I used(different sizes though)
excuse the mess, not done yet!
