Go Back   Lateral-g Forums > Vendor Specific Technical Discussions and Support > Roadster Shop Chassis and Components
Old 07-29-2013, 10:06 AM
RS-Chris's Avatar
RS-Chris RS-Chris is offline
Supporting Vendor
Default NEW! REVO '47-54 GM Pickup Chassis
Introducing the newest generation of our 1947-'54 GM pickup chassis featuring REVO IFS.
This chassis features a re-designed center section with improved 4-bar geometry and longer swingarm length for smoother ride. This generation '47-54 has improved triangulation between the new 1" splined swaybar tube and coilover mounts a lowered panhard bar for lower roll center and an added option for strengthened running board mounts.
A new and innovative integrated sway bar design allows the use of a 1” OD splined sway bar tube, with no external mounting necessary. The carefully designed packaging leaves one of the smallest crossmember footprints available today, leaving you with more room and clearance to position your drivetrain where you want it without compromise.
REVO IFS is a new standard. To create a new standard we had to start from scratch. REVO has been created from the ground up, leaving behind the antiquated Mustang II geometry and ride quality where it firmly belongs: in the past. Controlled roll centers, eliminated bump steer, and CAD optimized camber and caster curves provide a suspension that offers the absolute best combination of ride quality and street performance.
With 5.5” of wheel travel and positive and negative bump stops, the REVO front end allows smooth articulation through the full range of motion, creating the most comfortable, balanced and street friendly dynamics possible within this package. 115 unique components were designed and manufactured for this suspension, allowing a fresh design template to build the ultimate IFS without compromise.
Keeping with the latest manufacturing processes to raise quality while controlling costs; laser, plasma, CNC milling and turning are all employed in the manufacturing of these components. With a years’ worth of in house development, the REVO IFS has been fine-tuned and streamlined to redefine the standard for street performance suspension.
Standard Features
  • Wilwood forged Pro Spindle with steering arm
  • Afco ProTouring non-adjustable coilovers front and rear
  • 11" front disc brakes with black Wilwood 4 piston calipers
  • 1" Splined thru-frame front sway barMotor mounts for SBC, BBC, or optional LS motors
  • 10 gauge, fully boxed, fabricated frame rails that follow factory contours
  • CNC located mounting points for cab, bed, bumper, running boards, and core support
  • Roadster Shop "X-Brace" Center Crossmember with drop out trans mount
  • Exhaust clearance for up to 3" exhaust
  • Tig welded cross members and all chassis components for strength and appearance
  • Large diameter parallel 4-bar rear suspension with panhard bar
  • New Ford 9" rear housing with 31 spline axles, 57" or 61" track width
  • Rear drum brake with internal parking brake
Pricing, options and additional info can be found here: http://roadstershop.com/chassis/1947-54-gm-chassis/
[B][FONT="Arial"]WWW.ROADSTERSHOP.COM
