Old 10-23-2006, 06:36 AM
CamaroGbg's Avatar
CamaroGbg CamaroGbg is offline
Default How to bleed the clutch system?
I have the stock LT-1 clutch master and slave cylinder and was wondering how to bleed this system?
Can anyone help?
Mikael
Old 10-23-2006, 04:24 PM
GBodyGMachine's Avatar
GBodyGMachine GBodyGMachine is offline
1. Verify that all the lines and fittings are dry and secure.
2. Clean the dirt and grease from the reservoir cap in order to ensure that no foreign substances enter the system.
3. Remove the reservoir cap.
4. Fill the reservoir to the proper level with the required fluid.
5. Attach the J 43485 (Adapter) to the J 35555 (Mity Vac) or equivalent.
Important: Brake fluid will deteriorate the rubber on J 43485. Use a clean shop cloth to wipe away the fluid after each use.
6. Place and hold the adapter on the reservoir filler neck to ensure a tight fit. In some cases, the adapter will fit into the reservoir opening.
7. Apply a vacuum of 51-68 kPa (15-20 hg) and remove the adapter.
8. Refill the reservoir to the proper level.
9. Repeat Steps 6 and 7.
10. If needed, refill the reservoir and continue to pull a vacuum until no more bubbles can be seen in the reservoir or until the fluid level no longer drops.
Caution: The vehicle will move if started in gear before the Actuator Cylinder is refilled and operational Start the vehicle the first time in neutral to help prevent personal injury from vehicle movement and see it the transmission will shift easily into gear.
11. Pump clutch pedal until firm (to refill actuator cylinder).
12. Add additional fluid if needed.
13. Test drive vehicle to ensure proper operation.
84 Regal Project GBodyGMachine
[SIGPIC][/SIGPIC]
