Old 06-09-2006, 08:29 AM
Default "Stealth / hide a way " efi for older manifolds??
I cant remember where i saw an picutre of old carb manifold converted to efi . It had injectors under of the manifold,in cam valley side. Any ideas? Does it work ? Just bench racing here with an idea of stealth efi
Old 06-09-2006, 11:02 AM
4OfaKind's Avatar
4OfaKind 4OfaKind is offline
You may have seen me use one as an example in this thread:
https://lateral-g.net/forums/show...?t=4631&page=2
It is the manifold done by John Meaney (sp) and Troy @ Rad Rides for one of Troy's clients on a thirties roadster. It most definitely works.
Mal
Old 06-09-2006, 12:10 PM
Hello Mal!!
Thank you for your reply! Yes that was it. Now its in hard drive for ever
Do you have any how those electrical connection survive under the plenum with hot air / oil ?
Old 06-10-2006, 03:58 PM
4OfaKind's Avatar
I have no idea how they keep heat and oil from affecting the injectors. You might want to check with a specialist or your fabricator for that information. I simply find all the great ideas I like and might implement and then ask the cool informed guys here how I should go about it.
Mal
