Old 06-28-2018, 05:57 AM
69hugger's Avatar
69hugger 69hugger is offline
Default Quiet, mellow mufflers?
I need some help from those more experienced then me on muffler selection. This is for my '56 Chev pickup with a hot cam LS-3 and a 6L80E. I bought it with a horrendously noisy exhaust system. It had terrible harmonics, and it was torture to sit in the truck at idle.
I just had the entire system replaced with mandrel bent 2-1/2" stainless pipes, H-pipe, and Magnaflow 18" long mufflers. As the truck has a C-4 IRS suspension, there is no reasonable way to exit it at the rear. The exit is out the sides, ahead of the rear tires. The old system had turn downs, but it was blowing dirt all over the rear wheels, so the new system has straight out square tips.
I "auditioned" the Magnaflows, but the shop was in a metal high-roof building and what I thought I heard inside is not what I ended up with.
The new system is at least as loud as the old system, and with any reasonable throttle, it is way noisier. The harmonics issue is gone, but I don't think I can live with this. I have the Camaro with Flowmasters as the in-your-face vehicle, this one needs to be a quieter, mellower hot rod.
So I am looking for recommendations for a QUIET muffler. Performance is a secondary consideration.
Thanks in advance for sharing your experience!
Bill
Bill
'69 Camaro / 534 BBC / DSE Built
'67 C10 / LS-3 w/Magnuson / Roadster Shop Chassis (SOLD)
'71 Blazer / LT4 / 8L90 / Roadster Shop Chassis / Ride Tech Air Susp.
Old 06-28-2018, 06:28 AM
Ketzer's Avatar
Ketzer Ketzer is offline
I've only tried Magnaflow on my daily Yukon. Their cat-back system. A little too much sound for me on a daily and had a terrible highway drone. Flowmaster has several different styles of mufflers and they are rated by sound, I swapped just the muffler on my Magna system over to a flowmaster an have been very pleased... something I noticed though, usually the quieter the muffler, the bigger the muffler... pay attention to the sizes.
Jef-
The Following User Says Thank You to Ketzer For This Useful Post:
Flowmaster Exhaust (07-12-2018)
Old 06-28-2018, 06:30 AM
69hugger's Avatar
Thanks, Jef. Do you know which model Flowmasters?
Bill
Old 06-28-2018, 08:04 AM
Ben@SpeedTech's Avatar
Ben@SpeedTech Ben@SpeedTech is offline
I've tried several types of mufflers and the one I felt was the best for power/ flow and mellow quiet cruising was the Dynomax turbos. They're decently deep toned and quiet when cruising and come alive fairly well when you lay into it. As with other turbos they have internal flow direction changes but they have bends inside the muffler that direct and keep the flow moving smoothly instead of just dumping into a chamber and then moving through another tube, if that makes sense.
I grew up in the 80s and have always loved the sound of Flowmasters, but every vehicle I had them on from a street strip Nova to my 76 Suburban to my G-body wagon the drone was a little annoying. Their larger truck mufflers are said to cut down on that drone.
-Ben, Creative Director
Old 06-28-2018, 01:27 PM
Ketzer's Avatar
50 series Delta Flow is what I used on my Yukon...
Old 06-28-2018, 02:37 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
You could try adding resonators up stream of the mufflers if you have room.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 06-28-2018, 02:38 PM
Borla XS. Run your pipe/pipes (mine is 3" single) under the C4 pumpkin. Mount muffler(s) at end of vehicle, not under the middle. This is the best muffler I have ever had in my 20+ years of doing stupid hotrod things (and I am so old that I now hate loud exhaust).
The Following User Says Thank You to rustomatic For This Useful Post:
blowngasr (07-05-2018)
Old 06-28-2018, 07:06 PM
Musclerodz's Avatar
Is it an 18" case length or 18" overall? The biggest they make is 4x9, 24" overall (18" case) and is fairly quiet. I installed a pair on an LSX 454 and they was too quiet
Mike Redpath
Musclerodz & Customz
facebook page
Old 06-28-2018, 07:38 PM
out2kayak out2kayak is offline
Have you researched side branch resonator / Helmholtz chambers / "J" pipes? It may be a less expensive way to "tune" your exhaust.
http://penn.freeservers.com/jeep/wj/qfrexhaust/
https://ls1tech.com/forums/cadillac-...ltz-tubes.html
I know it's not a muffler, but it may be worth looking into.
Also, you may want to look at:
-- Joe
Old 06-28-2018, 07:39 PM
Try2paz's Avatar
Try2paz Try2paz is offline
I ran the Borla XS and it was pretty quiet..it also depends on muffler size.
I ran Billy Boats on my Mustang that were 20" long and even with full 3" exhaust and a fairly hot motor it was quiet compared to most to run 90DB at Laguna.
1967 Nova
2018 Camaro ZL1 1LE
