Old 04-26-2021, 04:36 PM
ProTouring442's Avatar
Default Help! Weird Issue L99/6L80E
We have a 2010 Camaro L99 (ECM and harness by Speartech) in my father's '59 Impala.
The issue usually happens when the car has been driven, then allowed to cool off. We get a no start condition where I have spark, but no injector pulse.
Although everything tested good, I replaced the crank and cam sensors and ignition switch "just because."
I don't see anything on datastream that looks out of place.
Thoughts?
You ever wonder what medieval cook looked at the guts of a pig and thought, "I bet if you washed out that poop tube, you could stuff it with meat and eat it."
Old 04-27-2021, 08:58 AM
Not a clue?
Old 04-27-2021, 12:52 PM
camcojb camcojb is online now
I would think it's an issue with the ecm not getting an rpm signal. Not sure why it only does it after a cool down. Have you looked at the battery voltage when cranking in this condition? If it has any kind of heat soak issue or similar and the volts are dropping to 10 volts or so it will cause what you're seeing. Had this on a friends car and a new battery with more cranking amps fixed it. Thing is the engine seemed to spin over fine, but looking at the voltage when cranking told us what was going on.
Old 04-27-2021, 03:49 PM
But wouldn't I lose spark, too?
Old 04-27-2021, 04:02 PM
If the battery voltage drops under 11 volts or so during cranking all sorts of weird things happen. I'm pretty sure that's what my buddies car was doing, spark but no fuel, but I'm going off memory. It's a simple thing to check though. As a test next time it happens plug in a battery charger and see if it starts. Like I said before his seemed to turn over normally, not slow at all, but it wouldn't fire.
Old 04-27-2021, 05:43 PM
It's something to think about... though the fact that it will then start on the third or fourth try (and start immediately, regardless of how long you had been cranking it previously), seems to demonstrate the battery has more than enough juice.
I do really appreciate the thoughts, though! Like I said, it's a weird one!
