Old 10-13-2022, 03:27 PM
colorado80439 colorado80439 is offline
Default Manual Brakes, what's stopping me??
I'm at the point with a 69 Camaro build where I'm ready for body and paint, was planning to go with the DSE vacuum brake master when I decided to look at manual brake options. The car all DSE equipped with 6 piston AP calipers front and 4 piston rear. L/S 7 with a healthy cam. Trying to decide between the DSE vacuum system, tandem maunual or full on brake pedal, firewall modification Tilton set up. Any recommendations with experience?
As always Thanks in advance Dave
https://tiltonracing.com/installing-...n-a-69-camaro/
Old 10-16-2022, 07:36 AM
572Camaro's Avatar
I’m a huge fan of hydroboost.
I’ve tried vacuum systems and manual with okay results.
After hydroboost, my Camaro stops like a dog hitting the end of his chain.
Old 10-16-2022, 07:33 PM
Good to hear, what system/brand do you use
Old 10-17-2022, 09:02 AM
572Camaro's Avatar
I used Hydratech Braking Systems.
They are top quality with great customer service.
If you go this route, PLEASE let us know so we can provide tips on hose routings.
You have to be careful with the return hose and where it dumps.
If you want more info on my application, go to Jim and Geralyn’s feature article on this website.
The Following 2 Users Say Thank You to 572Camaro For This Useful Post:
camcojb (10-17-2022), colorado80439 (10-19-2022)
Old 10-28-2022, 08:35 PM
Hotrodsofthemidwes Hotrodsofthemidwes is offline
I am kicking the same thing around. I have 14 inch Baer front with 6 piston calipers and 13 inch on the rear with 4 piston calipers. I’m considering doing manual brakes to keep the firewall as clean as possible and not have to worry about a vacuum issue with a big cam.
Old 10-30-2022, 08:59 PM
rocketrod rocketrod is offline
I'm actually switching from a hydroboost setup to manual brakes. I'd like to install a Tilton 600 setup but looking for some feedback as the install isn't trivial and not easily reversed.
Rod
1969 Camaro - LS2/4L70E
Old 11-01-2022, 09:35 PM
flyingv's Avatar
flyingv flyingv is offline
Wilwood just released this, which would be a much simpler solution than the tilton set up and provide the balance bar set up.
https://www.wilwood.com/Media/Brakin...eid=9c2c7cc5ad
Sent from my SM-S906U using Tapatalk
The Following 2 Users Say Thank You to flyingv For This Useful Post:
camcojb (11-01-2022), dhutton (11-02-2022)
Old 11-08-2022, 11:50 AM
Blown353 Blown353 is offline
Neat!
That's very similar to the factory firewall to dual masters with balance bar adapter that CNC Brakes used to offer years ago, but the Wilwood piece looks much cleaner.
Rob at No Limit Engineering also used to build something similar (a bolt on 2 bolt factory style master cylinder mount to dual master with balance bar adapter) that had a built in swinging intermediate pivot lever between the factory brake pedal and the dual masters to minimize side loading on the bores of the master cylinders. His adapter offered multiple bolt locations on the intermediate pivot lever to easily alter the pedal ratio without having to redrill your factory brake pedal. Not sure if he still makes it or not, but it was a cool piece.
Wilwood simplified things even further and appears to just have the balance bar sliding in a slot on the adapter to avoid twisting the balance bar and putting excessive side loading on the bores of the master cylinders. The slider might have a little more friction than Rob's swinging pivot lever solution and doesn’t allow easy adjustment of pedal ratio, but I bet the Wilwood piece still works just fine.
While a new pedal assembly with a built in balance bar along with firewall mods is a much cleaner and more compact solution than a firewall adapter that sticks way out, the Wilwood adapter is a great way to see if you like the feel and function of a manual setup with dual masters and a balance bar before you go slicing up the firewall up to install pedals, or if you prefer a "no mod" install.
I had the parts and was ready to slice up my firewall to install a full set of Tilton 600 pedals and 76 series masters for simplicity and a minimal look on the firewall, but when I decided to add ABS I found out that Tilton does not recommend the 76 series master cylinders for use with ABS as the pulsations from the ABS can damage the seals in the master cylinders. For ABS they said to use the 79 series ABS compatible master cylinders which are far more expensive and also have to be used with the far more expensive 800/900 series pedal assemblies, which have their own mounting quirks for a firewall mount setup as the master cylinders now move during the pedal stroke so you need a rubber lined seal plate on the firewall to allow the masters to move. While that’s OK for a race car, on a street car that sounds like an invitation to let hot air and engine noise into the car from leaks around the master cylinder seal plate… so I changed plans.
I'm now going with the DSE booster and master since the master is an OEM GM piece and compatible with ABS, and will have the ECM monitor booster vacuum levels with a late model OEM GM sensor/checkvalve at the booster inlet and the ECM can cycle a Hella UP5X series OEM auxiliary electric vacuum pump when needed to maintain vacuum in the booster. This arrangement of engine vacuum, check valves, and an auxiliary Hella vacuum pump is exactly how GM handled things on the CTS-V / ATS-V / ZL1 with vacuum brake boosters (before they went to the full brake by wire system with electric booster about 2 years ago.) A belt driven vacuum pump off a late model GM pickup would be another good solution as it's silent and wouldn't need any wiring, but it would be difficult to adapt to my Wegner accessory drive. The electric pump setup also has the advantage of being able to cycle and provide vacuum for the brakes even if the engine isn’t running.
When it comes to converting from power to manual brakes, just make sure you do the math for your current caliper piston areas and pedal ratio before converting from power to manual... some calipers with small piston areas just don't play nice in a manual setup, as you might not be able to get a master cylinder with a bore small enough to have reasonable pedal effort with them. A bandaid to that is to use very aggressive high-mu brake pads, but those kinds of pads often come with drawbacks on a street car like being excessively abrasive at lower brake temps which rapidly chews up rotors. A large piston area on the calipers for a manual brake setup gives you the widest options of pedal ratios and master cylinder bore sizes when it comes to dialing in the pedal stroke vs effort “feel” you are looking for.
1969 Chevelle
The Following User Says Thank You to Blown353 For This Useful Post:
camcojb (11-08-2022)
Old 11-11-2022, 07:18 PM
Someone over on PT just posted pics from No Limit's development car that's for sale, and it had a picture of Rob's bolt on balance bar setup.
It's not quite as compact as the Wilwood, but it does allow adjusting your pedal ratio by simply moving where the link from the brake pedal connects to the intermediate pivot bar in the firewall adapter. With the Wilwood setup you would have to redrill your pedal to alter pedal ratio.
If you didn't want to mod the firewall for Wilwood or Tilton pedals, that's the route I would probably take as you can easily adjust the pedal ratio between stock, higher, or lower by moving the link attachment point. He also offered them with a built in mount for a clutch master cylinder too, at least for 1st gen F-Bodies.
IIRC the 1st Gen F-bodies have a 6:1 pedal ratio in the manual brake pivot, which is pretty much where you want to be-- but having some easy adjustability is nice.
Either the No Limit or Wilwood setup sticks out from the firewall quite a bit, but you do get to avoid relatively permanent firewall mods. If you're going for the most compact look you can, it's hard to beat actually cutting and modding the firewall for Tilton or Wilwood pedals.
1969 Chevelle
The Following 2 Users Say Thank You to Blown353 For This Useful Post:
camcojb (11-11-2022), fleetus macmullitz (03-26-2023)
Old 03-21-2023, 09:38 AM
nickcornilsen's Avatar
nickcornilsen nickcornilsen is offline
I built this system for my car. Seems to work good, and I increased the ratio to 6.25.
The Following 2 Users Say Thank You to nickcornilsen For This Useful Post:
camcojb (03-21-2023), fleetus macmullitz (03-26-2023)
