Old 01-13-2025, 07:44 PM
HEEP's Avatar
HEEP HEEP is offline
Default Chevelle 12 Bolt Rear Brakes
Hello,
So I have been trying to work through the rear brakes for the Chevelle. I currently have a set of rotors for a 2014 Camaro that are 365mm in diameter. I'm trying to find a backing plate with the integrated parking brake on the back side of the rotor, instead of the normal caliper parking brake.
I don't mind buying used parts or even changing the brackets on the rear end housing. In fact, buying used parts and cleaning them up seems to be the process that I basically do. HAHA However, using factory parts is a goal if at all possible.
If anyone has a link to measurements, or even parts that you need to sell, please let me know.
Thanks,
Bill
Bill
My Build Thread;
https://lateral-g.net/forums/showthread.php4?t=40557
Old 01-14-2025, 11:02 AM
Have you tried https://www.kore3.com/index.php Tobin is a good guy and knows a lot about brake swaps using late model factory parts.
dhutton (01-14-2025)
Old 01-14-2025, 12:02 PM
dhutton dhutton is offline
Here you go:
https://bigbrakeupgrade.com/product-...2-bolt-8-28-5/
Old 01-14-2025, 03:00 PM
Try these guys https://millerbuiltusa.com/chevy-1012-bolt-base-kit/ modern hub style
Old 01-14-2025, 05:44 PM
HEEP's Avatar
Thanks guys, I'll look into all of those. My search did not come up with those for some reason.
Thanks,
Bill
Bill
My Build Thread;
