Old 02-07-2007, 08:51 AM
$mike70Z28's Avatar
$mike70Z28 $mike70Z28 is offline
Default 383 procharger
im looking to do a 383 procharger with all the goodys but im stuck on the heads looking at AFR 195 or 210 can you give some feed back
on the 210 where the header mounts is 1/4 " higher then stock will that be a problem for the headers and the valves are .05 higher will that be a problem for the valve cover thanks
