Old 03-22-2008, 08:12 AM
DDY RCKT's Avatar
DDY RCKT DDY RCKT is offline
Default LS1 Wiring harness question
Does anyone know what (if I can) I'd need to change on my LS1 wiring harness and computer (I'm sure I just reprogram this, no problem) that came from an automatic car to make it work with a T-56?
2002 Corvette Z06
Old 03-28-2008, 06:32 AM
GMracer's Avatar
GMracer GMracer is offline
well first off the trans wiring is different, so you need to adapt the wiring, and the PCM needs to be reflashed. Have you checked out LS1tech, I'm almost positive they have a write up on the swap.
Nick Schiffer
2001 Silverado Regular Cab Short Bed
Currently Under the Knife
Special Thanks to:
Air Ride Technologies - Wilwood Engineering
