Old 07-17-2008, 02:29 PM
Buick Motorsports's Avatar
Buick Motorsports Buick Motorsports is offline
Default g-body with AFX spindles
Hey guys need your help. I'm going to be ordering AFX spindles for my Regal, btw the car is equipped with 17" wheels.
I want to upgrade to four wheel discs. I don't want to use Baer, seems a bit pricey. What other options are there for complete kits.
I don't want to order from 5 different places.
thanks,
jason
Jason
Project No Mercy
85 Buick Regal
BUDGET BROKEN.....SO IS MY SPIRIT.....TILL SPRING!!!
Old 07-17-2008, 05:26 PM
chevyIIpost's Avatar
chevyIIpost chevyIIpost is offline
Talk with Frank at Prodigy Customs.........SSBC might be in your price range!?!
Ted Rea
"Don't drive FASTER than your guardian angel can fly"
Old 07-17-2008, 05:59 PM
hectore3 hectore3 is offline
Kore3.com or touringclassics.com
Old 07-19-2008, 11:19 PM
speedshopmike's Avatar
speedshopmike speedshopmike is offline
g-bodies don't need a tall-spindle conversion; why the afx units?
just looking to save the unsprung weight?
don't be a dick
Old 07-20-2008, 08:20 PM
7TSS's Avatar
7TSS 7TSS is offline
From what I've read in the past, the G bodies still benefit from better negative camber gain with taller spindles. Not too sure on other things though.
Old 07-20-2008, 10:26 PM
you could just run taller ball joints if you want more camber gain.
you'd be much better served spending your dough on superior brakes then other components.
Howe and several other companies make the tall BJ's.
pick up an issue of any stock car racing magazine; g-bods are still very very popular in lower levels of circle racing and there's a ton of good stuff for good deals for them
don't be a dick
Old 07-23-2008, 10:10 AM
Bumpsteer is also reduced tonearly zero by doing this upgrade. Since this car is going to see alot of street time and the roads here are all bumps. Worth the money.
Jason
Project No Mercy
85 Buick Regal
Old 07-23-2008, 11:20 AM
g-bodies dont have bumpsteer issues through the majority of their travel.
bumpsteer is created when the pivot point of the tie rod and the control arm aren't the same.
why do you think a taller spindle could alter that?
regardless, a taller BJ will give the exact same effect as a taller spindle.
but, by all means, go nuts on the trick parts.
at least you can brag about low unsprung weight and they look real pretty.
if you'd like to spend your money usefully, feel free to contact me; i will give you a great deal on Baer brakes.
don't be a dick
Old 07-23-2008, 11:53 AM
wiedemab's Avatar
wiedemab wiedemab is offline
I'm admittedly ignorant of the specifics of the G-body suspension geometry, but solely geometrically speaking, if you change the upper - outer pickup point for the suspension the upright is going to travel through a different set of points. Hence in the case with the taller upper ball joint giving greater camber gain. Depending on the position of the steering pickup points (outer tie-rod) the effect on the "bumpsteer" characteristics will be different. As the top of the spindle is "pulled in" during bump so is the steering arm. Obviously less if the steering arm is very low, more if it is high. I'm even simplifying it to an almost 2D view with this explanation.
I'm just pointing out that to say that a taller balljoint has no effect on the steering characteristics may not be entirely true. Probably in most cases, it would be negligible, but still worth considering.
Maybe Marcus from SC&C will chime in - he knows this setup very well and can explain the differences of the tall ball joint to the AFX setup.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 07-23-2008, 12:06 PM
well stated; that is all absolutely correct, but as you noted, the effect's (very) negligible in this case.
however, being very specific, i didn't say it won't alter steering "characteristics", i am referring strictly to bumpsteer.
changing camber gain could change other steering characteristics by altering the contact patch and thus required slip angles to achieve a given amount of directional delta.
don't be a dick
