Old 09-12-2008, 01:47 PM
rsk68's Avatar
rsk68 rsk68 is offline
Default Brakes not working well
Well i'm still working out the bugs and brakes are one of them, I have Willwood 6 piston fronts and 4 piston rears with a Wilwood 1" master cylinder, the pedal is rather hard and feels like it just isnt stopping the car, like theres just not enough pressure, i vacumm bled the brakes and cant remember if i bled the MC, any suggestions on what i should try or look for, i also have there praportioning valve but its screwed all the way in for an open circuit. I guess the first thing i should do is bleed the master due to i cant remember if i ever have.
RSK68
Rick Klein
Hood-latches.com
Cast Aluminum hood latches.
Old 09-12-2008, 02:32 PM
camcojb camcojb is online now
are these manual brakes? Have you bed the pads yet?
Old 09-12-2008, 02:41 PM
rsk68's Avatar
Hey Jody,
yes brakes are manual, and ignorance steps in, what do you mean bed them? are you talking about a stop and go type procedure to brake them in, if so no i havnt done anything other then try to stop and its a little scary.
RSK68
Rick Klein
Hood-latches.com
Old 09-12-2008, 07:38 PM
skatinjay27's Avatar
Originally Posted by rsk68 View Post
Hey Jody,
yes thats bedding them in... and if you dont recall bench bleeding the master then just do it to be safe... maybe check with wilwood on the proper bedding procedures ie:speeds/wait times for the pads you have i would bed them first before you attempt to bench bleed the MC cause either way the pads need to be beded and if thats the problem it saves you from haveing to pull the mc. have fun!
AJ
Old 09-14-2008, 02:40 PM
wedged wedged is offline
if you hadn't bled the mc, the pedal would be soft and spongy or just go right to the floor. It wouldn't be hard. It sounds like either your pedal ratio is off or the master cylinder has too large of a bore size for the calipers you are using.
Old 09-14-2008, 04:24 PM
ironworks's Avatar
What is the bore for your master? 1" for manual brakes and 1.125 for power brakes. Sounds like your bore is too big. Bedding the pads has nothing to do with the feel of the pedal. It helps the pads contact the rotor, but has nothing to do with the hydraulics.
Old 09-14-2008, 05:00 PM
I drove a car with those same brakes and manual master, and it was the scariest car I've ever driven as far as stopping power. The bedding of the pads helped, but did not fix the issue. As above, you may have to go to a smaller diameter master, re-locate the arm on the brake lever for more leverage, or go to power brakes. I'd call Wilwood to see what they say, but I personally hate manual brakes.
Do you have the rod connected to the correct hole in the brake lever under the dash (the higher hole is manual brakes), or can you move it up and drill a new hole(watch the angle, needs to not be severe, plus the higher you go the less stroke you get so it's a balancing act)?
Old 09-15-2008, 08:48 AM
rsk68's Avatar
hey Jody,
I will take a look when i get home tonight and see where the rod is on the pedal, I agree its a little scary and I may consider a Hydraboost, i have called over at Wilwood as i work about 200 yards away from them and they want to take a look at it also.
RSK68
Rick Klein
Hood-latches.com
Old 09-16-2008, 10:18 AM
rsk68's Avatar
Well I took a look last night and the rod is on the upper hole, so with that being eliminated I'm thinking just go Hydratech, I was looking at there site and there is no phone number to call them direct, PAUL are you here? I would like to talk to you.
RSK68
Rick Klein
Hood-latches.com
Old 09-17-2008, 11:27 AM
Payton King's Avatar
Default Your master is too large
Call Wilwood and speak with one of the tech reps and they will get you squared away. I had the same problem and had to size my master way down, but i am running a twin set up. 5/8 front and 3/4 rear with a 5.3 pedal ratio. If you have the rod in the top hole you should have a 6:1 ratio. A 7/8 or 3/4 tandem master is probably what you need. Something else to check...what pad are you running. If you are running a BP-20, it is pretty agressive and will not stop well until a good amount of heat gets in the pad. A BP-10 would be better for the street (cold stops) and will still take autocross abuse. Save the BP-20's for track days.
